Old 09-24-2020, 12:32 PM   #1
4x4swb1970
1970 K10 front disc brakes
I want to switch my front axles from drum brakes to disc's on my 70 K10. I have a parts 71 suburban 4x4 with front disc brakes. I know there are differences in the length of the axles, i was wondering if there was any way to swap the knuckles or if anyone has been able to put 71-2 disc brakes on a 70 before without swapping both axles. If I have to swap the axles I will but id rather keep my nice clean axles underneath the truck if at all possible! Thanks!
4x4swb1970 is offline   Reply With Quote
Old 09-24-2020, 01:07 PM   #2
Mike C
Mike C's Avatar
Re: 1970 K10 front disc brakes
The original axle in a 70 is an open knuckle and all the parts from the spindles out should be able to be swapped on with no problems from the 71.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-24-2020, 01:18 PM   #3
gmc684x4
It will be easier to swap diffs
Axle lengths should be the same
I had seen an article a while back going over all what to machine
I did not bookmark it unfortunately since i have a spare disc 44 and not interested in rebuilding the drum 44 i have for parts
On the open knuckle drum 44 short axle is thicker
i am on the understanding clocking on the backing plate is different as well and the spindles are different too
gmc684x4 is offline   Reply With Quote
Old 09-25-2020, 07:02 AM   #4
ohboy321
ohboy321's Avatar
My truck has a 70 chassis with drum brakes. I did a lot of research on this a few years ago and found that only the 71 disk parts will work on the 70 differential. Starting in 72 the axle shafts increased in diameter and would not work.
There are a few threads in here that talk about the subject. I also used the DANA/Spicer BOM/Parts listings found here to research: https://pdfslide.us/documents/spicer-dana.html
Page 116 shows that the axle shafts are the same for 70-71.
Ideally I would like to find a 71 differential to do the disk upgrade.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is online now   Reply With Quote
Old 09-26-2020, 12:28 PM   #5
4x4swb1970
Thanks a lot guys! I will try using my 71 k10 knuckles and if they don't work ill post on here and try to settle this
Old 09-27-2020, 04:11 AM   #6
ohboy321
ohboy321's Avatar
I will be very interested to know if this upgrade works. My front diff isn't all shiny, but I have 3.07:1 gear ratio and I am not sure how easy it would be to find a bolt in replacement with that gearing.
Steve/NH
