Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 09-22-2020, 12:48 PM   #1
Arndorfer
1949 Chevy w/292
I'm installing a Chevy 292 in a 1949 Chevy 1/2 ton. Does anyone know where I can get rear engine mounts for this setup? I'm looking for mounts that go between the bell housing and the crossmember. The bell housing connection site flares up which matches the angle of the crossmember. Thanks
Wayne
Arndorfer is offline   Reply With Quote
Old 09-22-2020, 02:00 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1949 Chevy w/292
First of all Great to see you on this site.
Maybe Aspen Parts in Arizona. Or, if you were a paying member you could place a request in the for sale section of the 60-66 parts, someone would surely have one there.
From the site rules: "As always a basic membership on the forum comes with no charge. You may post a reply in any of the Classified Forums. You will not have the ability to offer items "For Sale", "For Trade", or make a "Wanted to Buy" or "What's it Worth" post."
Old 09-23-2020, 06:37 PM   #3
Arndorfer
Thanks for the info
Old 09-29-2020, 08:39 AM   #4
old51sedan
old51sedan's Avatar
Wayne
Interesting putting the 292 in your 49 pickup. I have a 51 sedan and it has the front motor mounts along with mounts on the side of the bell housing, none under the trans. I take it yours is the same way? You didn't say as to what your using for a trans, but I take it you are using the original. I'm using an automatic in my 69 pickup, it has the 292 and I'm installing a 200-4R behind it. Being the 292 has side engine mounts and the trans mounts on it's own transmission mount you would not need rear engine mounts. It maybe easier to install if you would like an automatic, or they have 5 speed manuals with overdrives also that mount the same way. These would both make your truck a nice cruiser and give you better mileage.
This is all just a thought but if you go to the top of the home page and click on search you can put in anything you want information on and do some research. Which ever way to do it it will be a much better truck, good luck.
Being as how you are new to this site, you would benefit if you were to pay the $25.00 annual fee to join as mentioned earlier, there is a vast knowledge here on this site available to you that way. I believe you may have to join also to use the search. Good luck.
old51sedan is offline   Reply With Quote
Old 09-29-2020, 01:53 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
Registered users are members of the site. The search function can be used without upgrading your membership. Here is how > http://67-72chevytrucks.com/vboard/s...d.php?t=712263
The $25 is a yearly payment to join in as a supporting member of the site. Supporting members have a few more perks than registered users. Check out this thread for all the info about the ins and outs of membership. http://67-72chevytrucks.com/vboard/a....php?f=93&a=17
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-01-2020, 01:52 PM   #6
Arndorfer
I have a 5 speed Tremec. I think I'll be going with biscuit mounts that will go between the crossmember and the bellhousing. To achieve a 3 deg. pitch there's about a 1 1/2 inch gap between the two surfaces. Thanks for the help
1947-53 chevy truck, chevy 292, rear motor mounts
