60-66 Nut
Re: LS T56 to SBC
You're going to have to remove your bellhousing crossmember and add a rear trans crossmember. Then you will need a different clutch slave cylinder. Your factory brake/clutch master has too large of a bore. I fabricate and sell a booster bracket with the hydraulic clutch specifically for the '60-'62 GM trucks. It is possible I may be able to help with the trans crossmember too.
| Bookmarks |
| Tags |
| sbc 350, t-56, transmission swap |
