Old 10-05-2020, 08:20 AM   #11
Justin71105
Re: 1964 C10 fleet side swb
With the ring gear having the 11/63 probably be the 17 spline. Looking for some cheap 65-69 axles and 65-82 carrie/gears to replace them with as I finish up more stuff on my truck.
Found a set of 69 30 spline axles on our local truck page for free if he still has them, fingers crossed. Then just need a carrier/gear set and I can swap everything out with new bearing and seals pretty cheap. There is a 77 at the local pull a part I can check the gearing on, hoping its 3.73s and I can get carrier and ring/pinion. If not can atleast get the carrier out of it and buy a new set of gears later on when I'm ready to install everything.
Edit:. Need to research a little more and see if I can use the ring/pinion/bearings/seals already in mine with the 69 axles and 65-82 carrier. If so that will save me a good bit.
From what I am finding 65-69 axles and 65-82 spider gears are the minimum needed to convert.
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
BTR Truck Norris
Justin71105 is offline   Reply With Quote
