Old 10-01-2020, 06:25 PM   #1526
JMD
JMD's Avatar
Re: What did you do to your truck today.The 3rd chapter
Ditched the in cab gas tank and went with something a little more EFI friendly.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 10-01-2020, 11:12 PM   #1527
cornerstone
cornerstone's Avatar
That's pretty trick! How many gallons can you hold? Nice and clean install in a beautiful truck.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-02-2020, 06:25 AM   #1528
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Very nice, I'm also curious about the capacity too.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-02-2020, 07:38 AM   #1529
JMD
JMD's Avatar
Thanks guys, it’s a 60gal tank so I have the sending unit read empty when there’s about 20 gallons remaining. Even though the tank is baffled the pump was still starving for fuel under hard acceleration and left hand turns. I might install a sump at some point but for now I’m just enjoying being able to drive more than 100 miles between fill ups.
Old 10-02-2020, 09:14 AM   #1530
ohboy321
ohboy321's Avatar
I'm going to have to rent one of these. Need to do the 68 and in the past I've used ezoff and just my garden hose. Worked well but I haven't been able to find any oven cleaner in several stores . They've been sold out for weeks guess there's been a rush on even cleaners too
Tried engine cleaner but it really didnt work at all. The gunk stuff they must have changed the formula
I use Gunk on some things, but always follow that with degeaser. With the hot pressure washer I just used degreaser. The wand was a bit long, but being a 4x4 I had enough room to maneuver underneath. The 200+ degree water with high psi did a nice job.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 10-04-2020, 12:35 PM   #1531
ohboy321
ohboy321's Avatar
Removed my camshaft and lifters today. No mechanical issues found. It is a Gen I 5.3L 327ci that was rebuilt at some point. Next I will be replacing the valve springs and start cleaning it up for paint.
Steve/NH
Old 10-04-2020, 04:00 PM   #1532
89AKurt
89AKurt's Avatar
For someone mechanically challenged like me, adding the legal license plate light was a cinch! (previous owner put new bumpers on, but not this) And it worked first time!
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 10-04-2020, 04:04 PM   #1533
72c20customcamper
72c20customcamper's Avatar
Made it work for it keep. Not hard but enough
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-04-2020, 06:46 PM   #1534
Astro-Balls
Astro-Balls's Avatar
Made a Custom Cab cover for a neighbor.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 10-04-2020, 07:51 PM   #1535
72c20customcamper
Would like to have a couple of those you should sell them .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-04-2020, 09:42 PM   #1536
pjmoreland
pjmoreland's Avatar
Installed a steel lever kit in my heater controls and replaced the defroster ducts. Got the parts from GMCPauls, and the quality is top notch on both.
Also installed some stock valve covers that I bought from Ironhorse. Still need to find a grommet for the breather.
pjmoreland is offline   Reply With Quote
Old 10-05-2020, 09:38 PM   #1537
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
I cut down the stacks to be able to pull into my garage if I need to.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-05-2020, 10:51 PM   #1538
67C10Step
67C10Step's Avatar
Started putting the Inline Tube brake lines on my truck. Got the two rears along the rear end to the tee and flex line installed. Moving to the long line under the cab next.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-06-2020, 10:40 AM   #1539
OregonNed
OregonNed's Avatar
New carb in - drove it to a cruise in last weekend and took this pic. This week I am checking timing and finishing up the set up. Went with a 500CFM on the engine. It's running great - very happy with the upgrade.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-07-2020, 02:15 PM   #1540
pjmoreland
pjmoreland's Avatar
Found what I consider to be a super nice door to replace my damaged door. I've been looking all over and everything has been excessively rusty so far. Found this one 15 minutes from my house at a private wrecking yard that's not open to the public. The guy there was super nice and helpful. I have been stressing out about being able to find a nice door, so this is a big relief.
Old 10-07-2020, 03:12 PM   #1541
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I just sat back and looked at it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-07-2020, 03:38 PM   #1542
72c20customcamper
Nice . I’ve been looking for a set for the 68 stepper. I bought a decent passenger door but would like rust free ones. May have to take a road trip to Phoenix to visit the cousin. And do some scrounging
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-07-2020, 04:20 PM   #1543
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
Been wanting to get the letters shadowed now for awhile. Well today it got done and I also did the wheels on the 64 SS Impala while he was here at the house.
Those pictures will be in the general area.
Old 10-07-2020, 05:03 PM   #1544
pjmoreland
pjmoreland's Avatar
I can only imagine how hard it must be to find clean doors in NY
Old 10-07-2020, 07:41 PM   #1545
72c20customcamper
Hard to find a 8 year old truck with no rust.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-11-2020, 12:40 PM   #1546
Happy_dan
Happy_dan's Avatar
Found a place top mount tires on original friction ring wheels. Sanded and painted wheels and cleaned up hub caps as best I could. I will only use these for pictures and shows but I like the original look.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 10-11-2020, 01:16 PM   #1547
Andy4639
Old member
Andy4639's Avatar
Question Re: What did you do to your truck today.The 3rd chapter
Pulled the cluster out to see what happened to the tach.
Stud is broke off inside of it. I will have to call Manes in the morning to see if they will warranty it. It's less than a year old.
It just spins around it's not attached to anything. I can pull it up but not out.
Old 10-11-2020, 01:33 PM   #1548
68bowtie
68bowtie's Avatar
Perfect!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
68bowtie is online now   Reply With Quote
Old 10-11-2020, 04:00 PM   #1549
Stover93
Painting is now complete! I see now why folks hire this done. It’s a ton of work!
Stover93 is offline   Reply With Quote
Old 10-11-2020, 07:00 PM   #1550
jimijam00
Lowered the bench seat 2 inches with Full Custom Fab brackets, and wired up my audio system (Kenwood h/u and Infinity 4" and 6.5" speakers) from scratch.
jimijam00 is offline   Reply With Quote
