Old 10-07-2020, 04:13 PM   #1
SCOTI
SCOTI's Avatar
Rear Coil Spring Measurement
Does anyone have any used rear coil springs on hand that could measure the 'free' height?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-07-2020, 04:27 PM   #2
Boog
laying low
Boog's Avatar
Re: Rear Coil Spring Measurement
I think so Scoti. I'll see here in a bit.
Scoti mine are the originals off my 69 short stepper 1/2 ton. They measure 13 1/2” free height.
Boog
Old 10-07-2020, 05:25 PM   #3
SCOTI
SCOTI's Avatar
Thank you for the dimensions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-16-2020, 02:10 PM   #4
SCOTI
SCOTI's Avatar
Ok.... Revisiting this & I'm curious. I'd like to get additional dimensions from rear coil spring set-ups (just a few).
A measurement (bottom of the frame rail to top of the truck-arm as close to the coil as possible) from a truck as well as from a burb. Stock height is the desired priority but I won't turn down dimensions of a lowered combo if someone can easily get the info.
I have a non-stock 'research' agenda & some measurements from trucks assembled & on the road will help. My priority would be from Burb owners as they're heavier in the rear half of the chassis. The more info the better:
  • Measured from in front of spring or behind
  • Type of truck (short fleet/short step; long fleet; Burb; ETC)
  • Spring info (replacement coil; original coil; lowered coil)
  • Loaded/installed height
Thanks in advance!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-16-2020, 04:03 PM   #5
pjmoreland
pjmoreland's Avatar
I have 5" drop springs from GMCPauls on my 68 2WD short stepside. The loaded/installed height is 8"
pjmoreland is offline   Reply With Quote
Old 11-16-2020, 04:22 PM   #6
SCOTI
SCOTI's Avatar
This info will be a nice comparison & what I'm looking for so I'll add that to my notes. Thanks for measuring!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-19-2020, 03:45 PM   #7
SCOTI
SCOTI's Avatar
TTT... Keeping this on the front burner until I can get additional input.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-24-2020, 06:34 PM   #8
SCOTI
SCOTI's Avatar
Holiday is coming up....
Lots of folks might be off work & tinkering in the shop. Anyone that can take some measurements on the rear springs of their C10 or Burb would be appreciated.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-24-2020, 07:07 PM   #9
Jim Boy
Smile Re: Rear Coil Spring Measurement
I did mine yesterday. 68 long fleet rear springs 12 1/2" high. They were original springs. The truck seems to be 1" higher with new ones. Doing the fronts when I get around to it, thinking of rebuilding it all. Have a good one eh.
Jim Boy is offline   Reply With Quote
Old 11-24-2020, 07:37 PM   #10
SCOTI
SCOTI's Avatar
Thanks!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-24-2020, 09:27 PM   #11
MaximusD
MaximusD's Avatar
I pulled mine off last week, they are 13 1/2 inches high, still original.. 1970 c10 short wheel base, hope it helps. Happy Thanksgiving all
MaximusD is offline   Reply With Quote
Old 11-25-2020, 12:38 AM   #12
SCOTI
SCOTI's Avatar
Thanks!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-25-2020, 10:44 AM   #13
SCOTI
SCOTI's Avatar
For those that just looked @ this initial post..... I'm requesting dimensions of installed springs as well.
It seems the standard free height is fairly consistent & not much different vs. a 'new' coil. Now to see how much variance as installed. Drop spring info is appreciated as well for those that have the opportunity to provide it.
Thanks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-03-2023, 02:57 PM   #14
SCOTI
SCOTI's Avatar
Bumping this as changes loom closer & more data would be beneficial for direction.
Looking for additional rear coil spring heights on stock set-ups. Wanting to see if there's a fairly consistent avg height or if they're more random that not.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-03-2023, 11:10 PM   #15
nightmare
nightmare's Avatar
The free height of my stock 72 burb rear springs are 12.5 inches. I don't know if they are compressed from time, and I didn't get any installed measurements (didn't see this post until today).
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 10-04-2023, 09:20 AM   #16
SCOTI
SCOTI's Avatar
TY for the info.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-04-2023, 07:54 PM   #17
Jim Boy
Got to thikin about it and there could be a difference in height depending whether the springs are regular or heavy duty. Just a thought cause I have too much time on my hands that allows me to think!! Have a good one eh!
Old 10-04-2023, 08:54 PM   #18
SCOTI
SCOTI's Avatar
Correct, there is a possible difference thus my trying to get as much data as I can.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
