Old 10-07-2020, 07:50 PM   #1
EricU
How to mod C30 A-Arms for Bags?
Well, as usual my project C30 has spiraled out of control.
What started out as a simple static drop install on my 83 big brown turd has turned into yet another fully bagged suspension on my now new to me 89 C30 (yes I now have a 83 and an 89 one-ton duallys)
The rear will be pretty straight forward as I ordered up a complete 4-link setup from PB Fab.
For now at the front I am going to use Dominator 2600 bags and mod the A-arms that will attach the Bell Tech Drop Spindles
* What are you guys (Scotti, Scotti!) using to install the bags?
I was thinking of calling BC Fab as they are kinda local and getting a bolt in top bag mount.
For the bottom A-arm (pics below), weld in a flat plate across the bottom of the lower A-arm and weld in a cup?
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 10-07-2020, 07:52 PM   #2
EricU
Re: How to mod C30 A-Arms for Bags?
My upper A-arms
Old 10-07-2020, 08:04 PM   #3
EricU
Not really relevant to my question, but I sure do like looking at shiny things - So here are the new shoes for the C30
And yes, I make my kids hold up my stuff and look stupid for photos!
Old 10-08-2020, 09:55 AM   #4
SCOTI
SCOTI's Avatar
The duallys call for a heavier bag than a 2600. When I built a set of arms for my dually (from some extras), I pocketed the arms for larger RE-8/Firestone F7325's/26c bags (3"min; 5-6"ride; 9"max).
Despite my efforts to allow for max room, the larger OD bags were too close to the pocket edges for me. You could possibly get away w/the smaller diameter bags on a lighter set-up (sbc vs BBC) but my BBC/TH400 requires ~100psi to achieve ride height & rides very decent. Smaller bags would likely require more PSI which adds spring rate to the mix.
Using the cups adds to the overall spring height which I didn't want. By pocketing the arms, they sat into the arms like the coils would. The way I did mine also kept the 'pocket' flush w/the bottom edges of the arm.
In the end, I wound up using PB's 1" Forward lower arms so I could use the larger bags w/o issue & used home fabbed upper plates that attach under the x-member.
I have modified/stock upper arms. Since I raised my x-member, I needed steering shaft clearance (when air'd out). All the aftermarket arms would have required multiple steering u-joints because the front bushing barrel would interfere w/the shaft on the driver side. The OE arm only required a small clearance notch & allowed using stock straight steering shaft (now the Cherokee XJ set-up).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-08-2020, 02:15 PM   #5
EricU
In the end, I wound up using PB's 1" Forward lower arms so I could use the larger bags w/o issue & used home fabbed upper plates that attach under the x-member...
I plan on using the 2600s because that is what the PB rear kit uses and what they use for their front kit.
What you did to your lower A-arms is what I was trying to describe.
* What thickness plate did you use? 1/4" is what I was going to use.
I think that is what I am going to do first.
I'd like to eventually go to a full PB Fab front cross member - Just need to pay for my kid's school first ($$$)
Old 10-08-2020, 02:39 PM   #6
SCOTI
SCOTI's Avatar
I used 3/16 material. A larger round tube/pipe would be better (corners = possible stress points) but my local place didn't have anything large enough.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
