Old 10-07-2020, 10:11 PM   #1
89AKurt
89AKurt's Avatar
Question Why would new shocks make the ride WORSE?
Ordered from Shocks Warehouse, using their web portal. Clicked '68 etc. Got KYB - part # KY344068 and KY344085. Installed the rear shocks this afternoon.
I have a half ton, stock, coil springs.
Right out of the driveway, noticed it bounced way too much. It's occilating about 8 times before calming down over any bump. I will contact them next, is this typical when getting new shocks?
1968 C-10 Long Bed Blue Cloud
1956 GMC 100 GYMEE
1969 Corvette that identifies as a Ferrari Daytona Spyder Fakerri
2016 Honda Civic EX-T Stealth
89AKurt is offline   Reply With Quote
Old 10-07-2020, 10:21 PM   #2
CastIron
CastIron's Avatar
Re: Why would new shocks make the ride WORSE?
How long after you installed them did you test it? Sometimes when shocks (or struts) are installed they have to sit a little while before dampening properly. I believe it has something to do with gravity and the oil. If it still does it tomorrow, I'd suspect you got some bad shocks. I haven't seen that with KYB shocks before though. I have some 20 year old gas-a-just shocks that still work fine on my truck. (20 years old, but low low miles)
CastIron is offline   Reply With Quote
Old 10-07-2020, 11:00 PM   #3
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Did you bleed them? Read the instructions on the box, this may help.
~Steven
Simi Valley, CA
Old 10-08-2020, 02:01 AM   #4
89AKurt
89AKurt's Avatar
I'll report back.
1956 GMC 100 GYMEE
Old 10-08-2020, 02:03 AM   #5
89AKurt
89AKurt's Avatar
Good question, the paper instructions are in universal Greek with numerous types of shocks. The first illustration shows drilling and draining the shock, then the last picture has a trash can, so good thing I didn't jump on that!
1956 GMC 100 GYMEE
Old 10-08-2020, 11:28 AM   #6
Steeveedee
Steeveedee's Avatar
Sorry, I was tired and it was close to my bed time. Didn't mean to come off like a wise guy.
~Steven
Simi Valley, CA
Old 10-08-2020, 12:14 PM   #7
geezer#99
geezer#99's Avatar
Gee Steve when you said bleed em I thought you were referring to the age old priming method.
Here’s some info on priming.
https://www.onallcylinders.com/2015/...g-your-shocks/
Old 10-08-2020, 02:57 PM   #8
kwmech
I've only seen this once before if the box happens to be sitting on the shelf for a long time on its side.
Old 10-08-2020, 03:09 PM   #9
SkidmoreGarage
If they are as bad as you say, i would take them off and try to extend/compress them by hand. It should be pretty obvious. Especially if you can compare them to what you took off.
Is there any chance they were returned and then shipped to you?
SkidmoreGarage is offline   Reply With Quote
Old 10-08-2020, 03:17 PM   #10
Steeveedee
Steeveedee's Avatar
Yeah, being tired got me on that one too! Priming is the word, but I learned it as "bleeding".
~Steven
Simi Valley, CA
Old 10-08-2020, 03:25 PM   #11
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I’ve tried a lot of different shocks for my 70 , they were always to soft or hard as a Rock.
I finally had enough and went with QA1 Adjustable coil overs Front and rear, 18 settings
I found the perfect ride. You can also get double adjustable like for Drag Racing.
I know this probably doesn’t help you and it’s expensive. I just couldn’t find a shock I liked
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 10-08-2020, 03:33 PM   #12
89AKurt
89AKurt's Avatar
No worries! It's like I tell my wife when she asks about her car, I say "did you read the owners manual?"
1956 GMC 100 GYMEE
Old 10-08-2020, 03:34 PM   #13
89AKurt
89AKurt's Avatar
Thanks, I did look at that.
Report back to CastIron, same this morning.
1956 GMC 100 GYMEE
Old 10-08-2020, 03:36 PM   #14
89AKurt
89AKurt's Avatar
I tried to compress/extend before putting on, must not have tried hard enough. I checked the old shocks, they were not loose or sloppy. Box seals were still intact.
1956 GMC 100 GYMEE
Old 10-08-2020, 03:38 PM   #15
89AKurt
89AKurt's Avatar
Thanks, I consider this a clue. I didn't see a need to go high-tech with my beater.
1956 GMC 100 GYMEE
Old 10-08-2020, 09:34 PM   #16
Barnfind46
Barnfind46's Avatar
Not sure if this is the case but I asked for shocks my C-20 and they made it ride terrible. Found out they were to stiff. Went with a different shock and all was good. The first brand had different valving. May be the case with the C-10 also. Just a thought.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 10-14-2020, 11:20 PM   #17
89AKurt
89AKurt's Avatar
So I should just give up with Shocks Warehouse, their customer service is totally lacking.
Something I noticed in the picture of the UPC label, the part number is:
344085
NL2C A is on one box
NKEC B is on the other box
1956 GMC 100 GYMEE
Old 10-17-2020, 02:11 PM   #18
89AKurt
89AKurt's Avatar
Dropped in to my trusted mechanic, who researched his source for shocks, discovered that Shocks Warehouse sold me the wrong shocks. I should have known better, when the website prompt did not have 'C-10' to choose from, that was a sign. He told me about priming the shocks, compress at least 3 times and let it return, the Japanese translation of Greek instructions show nothing about this procedure. He said there is a difference between coil spring and leaf spring, which explained my description of what's going on. When he ordered the correct shocks, had trouble finding them in stock. So I have KGS416 rear and KGS409 front coming, and will let him deal with the warrantee hassle.
Now I need to sell these shocks......
1956 GMC 100 GYMEE
Old 10-17-2020, 10:31 PM   #19
Barnfind46
Barnfind46's Avatar
Glad you were able to come up with a fix. let us know the outcome.
Old 10-28-2020, 02:48 AM   #20
89AKurt
89AKurt's Avatar
Darn right I will!
YAY! Now I don't feel so dumb. My mechanic had a heck of a time getting the shocks. His original source had declined his order three times, website showed in stock, different people went to the shelf and found none, so they kicked it back, THREE times! He went to another source, they had one set left, he said I got the last shocks for my truck on the planet. Thanks to CV-1984, manufacturing slowed or stopped, and warehouses became empty. He said '09 Dodge pickup shocks do not exist.
He also got the better ones:
KYB KG5416 (rear)
KYB KG5409 (front)
He also got the heater fan and back-up lights to work.
But, something like this is to be expected for a 52 year old pickup, he discovered something is missing.
[/url]
I'm amazed how this truck has run as well, on modern vehicles when something is just a little off, it just quits working.
1956 GMC 100 GYMEE
Old 10-28-2020, 10:31 PM   #21
burnin oil
I put KYBs on an 2wd 06 Dodge 2500 about 2 months ago. Much better ride than the previous shocks that were way to stiff.
burnin oil is offline   Reply With Quote
Old 10-29-2020, 09:02 PM   #22
'68OrangeSunshine
'68OrangeSunshine's Avatar
Hey Kurt, I just put new KYB 344068 shocks on my '68 C/10 Stepside. They work great. Lost a lot of shimmy on the front end at freeway speeds 65-80 MPH. My KYBs are black.
My mechanic also helped me install new hood hinges and springs [ GM, but made for our vintage in the Early 2000s -- I have P/Ns]. Before the hood wobbled at speed. It was hard to close -- had to be slammed. And the rear stood up 3 to 4 inches. Now, I can close it with 2 fingers, there's no wobble and no rise at the rear.
Rear shocks were ordered from a different vendor [RockAuto] and got in yesterday.
P/N: KYB KG5416. They are a 3-level adjustable shock for Rear, Coil, springs. I will probably set them for Medium. Can't get my guy to come back til Monday.
Stepside is about to roll thru 400,000 and needs to pass Pima County emissions before re-registration, Due 31 OCT.
shocks
