![]() Join Date: Jul 2015
C20 trailer hitch recommendations
I have a 74 C20 long bed stepside with a 454. I think it used to have a huge step bumper on it with the hitch integrated, so at the moment I have no hitch on it. I'll want to be able to tow a car hauler with no issue, atv trailer, sometimes some equipment trailer (i.e. bobcat).
What's a good receiver hitch to get without breaking the bank? Thanks! Last edited by 69Tom; 10-07-2020 at 05:19 PM. |
Re: C20 trailer hitch recommendations
Some of those HD step bumpers were rated to tow 10,000lbs. Just install the proper sized ball in one of the provided three holes. The hitch thing became the norm when the government started playing with bumper requirements.
If what you are wanting to tow uses a ball mount, might see if you can find a HD step bumper in good shape. A few years back I found one in the local Pull-A-Part for $30. Took several trips before one showed up. Otherwise, see if there is a custom hitch place nearby. Often they can make one to your specifications for the same or less money then buying a pre-made hitch. Figure out what you want for a bumper and possibly a spare tire carrier first so they can design the hitch to fit. You often have to slightly relocated the under bed tire carrier. |
Going with no bumper. I don't have a spare tire at the moment, so I guess I'd have to give it some thought whether I want/should have one or just do without.
I've towed lots of stuff with a factory step bumper.
But I can't believe there aren't off the shelf receivers still available?
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
Tom, I have a 2" receiver hitch on my K25 that bolts up to the rear frame rails (already installed when I bought the truck). Regularly tows an 18ft tilt deck trailer without issue, usually loaded with tractors. I won't have a chance to get a better picture until the weekend or next Monday, but here's one below that kind of shows the hitch in the background. Not sure of the make...
Active Member
![]() Join Date: Jan 2017
I put a Curt hitch on my 1978 C20 about two months ago, 4 of the 6 bolt holes lined up on the frame, two had to be drilled out on the frame.
#9 | ||
I used the 67-72 ECE Hidden-Hitch set-ups on my 74 & Dually. The outer holes aligned w/holes in the frame but the center mounts required tweaking. I bought a Curt CLASS IV hitch for my OBS '99 last year but haven't installed it yet as I have to cut off remnants of an earlier welded-on hitch to allow the install. The Curt hitch I got is definitely a nice piece. Solid materials, coatings, & even nicely plated hardware.
