Re: 79 Trans Am 403 Olds
I have owned several 403 powered T/A's but I never had cooling or water pump issues with them so I can't speak directly to your question. However they are not that different than a Pontiac engine and the impeller design and installed clearance makes a big difference in flow rates.
The stamped steel impeller are not very efficient and I always try to avoid them. 1st photo A cast iron or machined impeller is a better choice in my opinion. 2nd photo. I don't know about Oldsmobile cross over of impellers but on Pontiacs the mid 1960's impellers are cast iron with more vanes and they can be retrofitted into the 1970's water pumps. The clearance between the edge of the vanes and the pump body will also affect flow. Too far from the body and you get poor output. I've seen rebuilt pumps with 1/8" plus of clearance. See the 1st link for a better explanation. 2nd link to a high flow Oldsmobile pump. Good luck with your inheritance. https://butlerperformance.com/n-1339...ter-pumps.html https://flowkoolerwaterpumps.com/pro...-ac-water-pump
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
