Old 10-11-2020, 07:32 PM   #1
msg
Deluxe heater control assembly into the non deluxe dash question
Now that I am going to have the Vintage Air Sure Fit the assemly Im restoring looks like I need to bend the screw mount tabs and find the right screws and j clips to mount things up. Anyone able to tell me how they manage this? The install manual shows a jnut at the top of the assembly?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-11-2020, 08:37 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Deluxe heater control assembly into the non deluxe dash question
As I recall Vintage Air has instructions.
Old 10-11-2020, 08:49 PM   #3
nsb29
nsb29's Avatar
You need 2 #6 screws and U nuts bend the tabs so they are parallel with deluxe controls. The controls have a bracket that bolts to bottom side of the dash
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-11-2020, 11:13 PM   #4
msg
It looked like the tabs should be bent, is there a trick to doing it to not have them misalign or wreck the dash? I was going to use vise grips and just clamp close to the dash and bend away. Ill look for the #6 u nuts and screws thanks!
Old 10-13-2020, 09:47 AM   #5
spudder
Active Member
Put some masking tape on the tabs and then use vise grips to bend them. Clamp the vise grips on about as far as you can.
spudder is offline   Reply With Quote
Old 10-13-2020, 07:41 PM   #6
msg
Ive bent the tabs and tried the j clips and they end up shimming the unit down causing the unit no to fit so I just rested them on top and thread the screw through and got that worked out.
Old 10-13-2020, 07:48 PM   #7
msg
But now I am having trouble getting the unit to sit flush. When I put the bracket into what I assume is the right positioned hole (the one closest to the driver) I still have a large gap at the bottom. I'll have to look for the screw to thread in pretty sure I have it, but it doesnt seem like the alignment is right. I need more pressure on the unit forward into the dash. If I take my hand and puush it forward it does fit flush but the bracket below is off a good bit. Anyone run into this issue?
