Rain-X Latitude 16" Wiper Blades Work Fine
Just thought I'd mention that I replaced my wiper blades on my '71 Blazer with some Rain-X Latitude 16". Worked like a charm. Our trucks call for 15", but these 16" blades work fine and have just a bit more coverage. Still an inch away from the window gasket with no problems. Here is a link to the info on the blades: http://www.rainx.com/product/wiper-b.../#.UvVqC7R_QYt
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
Chance
![]() Join Date: Sep 2001
Re: Rain-X Latitude 16" Wiper Blades Work Fine
That's good to know.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
20' Daredevil (Ret)
![]() Join Date: May 2003
I wouldn't be surprised if just about any 16" blade would work. I switched to NAPA off-the-shelf 16s years ago when I had trouble finding 15s.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
These are integrated blades and arms, right?
What I've been looking for, and can't seem to find any more, are plain old wiper refills....just the blades, nothing else. What gives?? I guess there just isn't enough money in them, otherwise....
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
#5 | |
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
These are just the blades. You switch out a plastic piece in the blade and it just slides over the end of the arm.
![]() Join Date: Oct 2009
now I'm confused... Did you buy these and replace JUST the rubber or the whole blade arm?
I'm in the same boat as slikside, I just want a wiper refill, want to retain my stainless arm AND blade holder. Appreciate any info - and thanks for posting this. |
Quite possible. They do say wiper refills. Not sure about the part number, are they 15"?
So, you didn't use these because you didn't want to use the stainless blade holders that you already had....you wanted the integrated type?
They are the complete wiper blade assembly. Springs etc. Just not the arm that attaches to the motor shaft. There is a link on the original post that tells everything about them and more...
I bought them for performance, so I wanted the best I could find. Wasn't so much looking for original parts. They work really well, so far.
#11 | |
This just slides in as all the old ones used to, which lets you keep your stainless arm or blade whatever it's called.. Don't want to hijack TonyJohnson, good info. They look like they work well. ![]()
I drive 58 mi to work 1 way, those would work good on my honda! Lol. Yes I said honda
No problem, Shawn. I can understand folks wanting to save money and/or stay stock. I just want to make it through this crazy winter... lol
Those stock ones are pretty darn simple.
If you want the original look, you can still get the ANCO 15in refill if you look around ? Got 4 packs last time in my local "Bakters Auto Parts store !
71 C-20 07 Magnum RT AWD |
#15 |
Sorry for the hijack Tony, Mark, etal,
ANCO U15R for the refills about $7 a pair available on Amazon and elsewhere. ANCO 91-15 for the SS & rubber blade assembly, about $15 each also on Amazon and elsewhere.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#16 |
After this winter, I won't be using the Rain-X Latitude... The problem is the plastic clips that mount the arm to the blade can't hold up to freezing weather. I've broken 3 this winter... It breaks at the spring clip that seats the blade on the pin at the end of the wiper arm. Gotta do some research, but I'll probably go back the the stock type... They worked great in lesser conditions, for you guys in Cali...
#17 |
Tony- Try a pair of the Napa Vista's, part # 60-1643. They seem to hold up well in all weather conditions, and should clear just fine. I have the stock Trico's I feed refills into on my 69 C10, but I run the Vista's on my "newer" vehicles (86 Buick Park Ave, 88 K1500, 92 K1500, 92 Lumina, 93 Suburban) and they hold up perfectly. I have had the same problem with the Rain-X blades as you have had too. If you run your pickup year round, they are "frameless" and you won't have to stop every 2 minutes and beat the ice out of the frame just to clear a small spot on your windshield.
My friends describe my house as the small town used Chevy Pickup dealership. |
#18 | |
#19 |
Thanks. Might give these a try Last edited by Wobpb377; 10-14-2020 at 01:13 AM. |
#20 |
![]() Join Date: Feb 2002
A little trick I've kept to myself, is to put a 16'' wiper blade on the Drivers side, where there's more room, and a 15'' on the Passenger side.
Back in the Eighties, Dual Wipers were a fad. They worked great in heavy rain, snow mud. But they only came in 16''. That's when I tried 16 inch wipers. Sometimes it's hard to find 15'' wipers.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-14-2020 at 06:19 AM. |
#21 |
![]() Join Date: Mar 2005
You mean there are others that drive their trucks in the rain?? Don't tell me it's so!
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
