Old 08-06-2012, 10:59 AM   #1
roushinator
roushinator's Avatar
72 C10 Cab/Bed Weight and Lift Question
So i have a few questions.
How much does an empty 72 C10 Cab weigh?
And how much does a 72 C10 step side bed weigh?
And has anyone see a homemade or some kind of kit that connects to the rafters in a garage that would allow you to use pulleys to hoist the bed/ empty cab off of the frame. Maybe a 2-4 pulley system that would distribute the weight? I am not looking for anything to lift massive weight just a system that would allow me to lift the bed/cab off and roll the frame out to work on it and when done roll it back into place. I am just trying to optimize limited space. Thanks.
roushinator is offline   Reply With Quote
Old 08-06-2012, 12:49 PM   #2
Ackattack
Ackattack's Avatar
Re: 72 C10 Cab/Bed Weight and Lift Question
I'd venture to guess a short fleet bed weighs ~300 lbs. Me and a buddy moved mine.
The cab is really going to depend how much of it is still there (gas tank, seat, steering column, brake booster, A/C, windshield, door, etc). Probably around 300 lbs stripped also.
Ackattack is offline   Reply With Quote
Old 08-06-2012, 02:06 PM   #3
69 gmc
69 gmc's Avatar
300 COMPLETELY empty sounds about right cause i was able to lift it with just one other guy.
Calder
69 gmc is offline   Reply With Quote
Old 10-16-2020, 07:57 PM   #4
Mbeef61
Mbeef61's Avatar
I know this is really old but I wanted to see if you ever made anything. Thinking of doing the same thing
Mbeef61 is offline   Reply With Quote
Old 10-16-2020, 08:05 PM   #5
72c20customcamper
72c20customcamper's Avatar
Double pulley livestock lift should work I used a simple a frame lift for mine
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-17-2020, 06:18 AM   #6
BigBird05
I made a lift bracket and used my engine hoist.
BigBird05 is offline   Reply With Quote
