Old 07-03-2004, 01:31 AM   #1
gregbr
Senoir Member
gregbr's Avatar
Location of build sheets
Where do you typically find the build sheet in our trucks? I had one in the glove box when I bought the truck from the 2nd owner. Did GM hide more than one in the trucks?
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 07-03-2004, 05:50 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Sometimes there was one under the bench seat springs on the passenger side. I found the one for my stepside inside the passenger door at the bottom when I was changing out the inner panels. It was a jigsaw puzzle by then. I also was working, last year, on the electric seat I put in that truck 25 years ago. [It came out of a '69 thunderbird.] The build sheet for a '69 T-Bird was inside the drivers' seat back panel. Interesting reading about a car that wrecked who knows when.
Old 07-03-2004, 09:07 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You can also find the build sheet's in the seat's of our truck..
FRENCHBLUE72 is offline   Reply With Quote
Old 07-03-2004, 11:26 AM   #4
sactoC10
71 DELUX
sactoC10's Avatar
Post
I've found three sheets (in two different Fremont built trucks) tucked under the wire cushion supports of the seat, the rear side and the bottom.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 07-03-2004, 11:38 AM   #5
demi
demi's Avatar
Here's one I found behind the seat back - too bad it's in pieces.
demi is offline   Reply With Quote
