Old 09-22-2020, 10:05 AM   #1376
youngrodder
youngrodder's Avatar
Re: 53 Surburban "Family Truckster"
Originally Posted by layinrocker65 View Post
Which US Mags did you go with?
I haven't pulled the trigger yet but I'm strongly considering these.
I plan to powder coat them fully to de-bling them.
That's where my head is at currently.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 09-22-2020, 03:55 PM   #1377
layinrocker65
layinrocker65's Avatar
Those would look really good.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 09-30-2020, 04:25 PM   #1378
rollinrooster
rollinrooster's Avatar
Originally Posted by youngrodder View Post
A little more progress on the exhaust. Next up installing o2 bungs and finish welding. We (Josh) have most of the heavy lifting done. The rest will be pretty straight forward. I ordered up a few more SS isolators. I'm digging the placement of the mounts. I will snap some pics once in place. I also worked on finalizing my driveline angles with the help of Nate from Porterbuilt. I used Delrin for my trans
and carrier bearing spacers which is a dense very hard plastic. Its easy to drill and lighter than a hunk of metal. I have been focusing on a bunch of little stuff like painting up the driver shaft. Just stuff that is needed prior to the body going on.
My friend/coworker Vic stopped by to check out my project. Vic has about 9-10 cars and trucks. All varying conditions/styles. He drove his (real) patina 55 BBW truck...
Marc
Hey man... Vic has to many cars / trucks. Have him sell me the 55
rollinrooster is offline   Reply With Quote
Old 10-01-2020, 09:25 AM   #1379
youngrodder
Funny when I read your comment, I thought How does he know Vic..I forgot about my earlier post....I'm trying to talk him into bagging it with a GSI chassis. I'm great at spending other peoples money.
Marc
Old 10-16-2020, 08:14 AM   #1380
youngrodder
I have been putting in time on Coopers OBS Blazer so I have not been working on my the Suburban. Plus I'm still waiting on my buddy to glue my block back together. I did go out last night to work on it a little. it is funny how you have a plan when you are constantly working on something. Step away for a bit and you loose track of what's next....
One aspect of my last build that I was not fond of was the wiring (which I was responsible for). That truck had SO MANY circuits. I figured a little better preplanning will go a long way. I installed a removeable panel to mount most of the circuit boards to. I drilled a hole and inserted a grommet for a wire pass thru.
I also ran out at lunch an grabbed a small section of SS 1.5" tube to complete my cooling hoses. I will paint it satin black at some point. For the lower hose I was able to use a 1.75" - 1.5" 90 degree elbow. It worked great.
Thank you
Marc
Old 10-16-2020, 10:32 PM   #1381
oldman3
oldman3's Avatar
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 10-17-2020, 09:01 PM   #1382
youngrodder
I worked on finishing up my gas tank vent. I purchased the vent off eBay. I had to build a small bracket to attach to an existing bolt from my Porterbuilt set up.
I like how it turned out, tucked up and out of the way.
Marc
Old 10-17-2020, 11:32 PM   #1383
mongocanfly
mongocanfly's Avatar
Nice vent Marc ...do you have a link to it?...I've got one for mine but I'm not liking it..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-18-2020, 08:40 AM   #1384
8man
The vent looks good. Much better than the PVC one I built.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 10-18-2020, 02:00 PM   #1385
youngrodder
Originally Posted by oldman3 View Post
Looking good...Jim
Thanks Jim
Here you go. This one is sold out but other people are selling them
https://www.ebay.com/itm/Holley-Perf...53.m1438.l2649
Thank you. I'm picky. I looked at a bunch of different ones before buying his one.
Marc
Old 10-18-2020, 02:17 PM   #1386
youngrodder
I worked on my AC condenser. You ever notice that when you move one thing, three things down the line then need to be modified. This is where we are at with mounting the condenser. Since I pushed my radiator forward for more clearance with the front of the engine my brackets that held the condenser and dryer would no longer fit.
I added to horizontal supports. I installed nutserts to bolt the condenser to. I also chopped up the Vintage Air brackets so I could repurpose it to mount the dryer to my modified core support. It all turned out great. A little touch up paint and we are in business.
Marc
Old 10-19-2020, 10:24 AM   #1387
mongocanfly
Thanks Marc..!...for the link..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-19-2020, 11:46 AM   #1388
Tempest67
Tempest67's Avatar
I enjoy seeing your work, very nice and clean.
Keep it going, and thanks for sharing
Tempest67 is offline   Reply With Quote
Old 10-21-2020, 10:12 AM   #1389
youngrodder
Thanks, I try....much appreciated!!
Marc
Old 11-03-2020, 09:51 AM   #1390
youngrodder
My fabricator friends made it over on Sunday to glue the broken starter tab back on the block. He ordered some special rod and it worked great on this repair. It had lower melting point so we didn't need to heat the area so much. I'm purposely not grinding the welds smooth as I want as much material as possible. I think the repair turned out great (all things considered)
Last night I re-tapped the starter bolt threads, installed the new starter, hooked up a bunch of misc. wires and pulled the plugs. I cycled the motor without any plugs to push the gas out of the #7 cylinder which caused the hydro lock. Gas shot across the garage. I was not prepared for that. Now I know why they say make sure you have no power going to the coils as it could easily cause a fire.
Later this week I will attempt to test fire the motor (again)
Marc
Old 11-03-2020, 09:55 AM   #1391
mongocanfly
that shooting gas is what got my coworkers truck burnt to the ground...glad you didn't have any sparks...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-03-2020, 10:13 AM   #1392
oldman3
oldman3's Avatar
Marc, repair looks great, hope next start will fire right up and run...Jim
Old 11-03-2020, 10:13 AM   #1393
Tempest67
Tempest67's Avatar
nice repair, a coat of paint and no one will ever know.
Old 11-03-2020, 10:22 AM   #1394
youngrodder
I can believe it. Yes. I made sure to unplug the main feeds that power the coils.
Marc
Thxs, I hope so...I just have to get my nerve up to try it again. I didn't want to rush it last night. I made some good progress.
Thank you...
Marc
Old 11-04-2020, 01:13 AM   #1395
Clarance J
Clarance J's Avatar
Hi Marc. Really like your build.
Just wanted to make a comment about the hydro lock in your engine. Check your oil before you fire it up. I had that happen to me years ago while I was at work one day. Forgot to switch off electric fuel pump. Pulled the plugs and cranked the engine and gas shot out the #7 cylinder also. What I want to say is that enough gas had gotten past the rings and drained into the oil pan. It was an hour drive home so I had to get new oil and filter and change it in the parking lot at work. Made for a long day. Your oil might be ok but I would check for gas before starting.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 11-04-2020, 10:07 AM   #1396
youngrodder
Earl
Thanks Earl. I don't think it contaminated my oil. We did check the dip stick and we also stuck noses down the fill spout to see if we smelled any gas in the oil. Did you drain your oil to check it? How did you know your oil was contaminated?
Marc
Old 11-06-2020, 10:07 AM   #1397
youngrodder
Earl
As much as it pained me to drain $40 worth of synthetic oil with no run time, it was the right call. The oil did have a gas smell to it when I drained it. After everything I went thru with the first test fire I wanted to take all precautions.
Test fire #2 coming this weekend.
Marc
Old 11-06-2020, 10:21 AM   #1398
mongocanfly
Good luck..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-06-2020, 11:28 AM   #1399
youngrodder
Good luck..!!
Thanks Greg..hoping for the best.
Marc
Old 11-08-2020, 10:32 PM   #1400
youngrodder
I wish I had a successful test fire to report.....but I don't. I'm closer. It sounds like it wants to fire off but something is not quote right. Not sure what the deal is. I will trouble shoot and I will call BP Automotive tomorrow to make sure I have it wired correctly....
I did make some progress on a design for a tranny cover. I didn't need a really tall one but it needed to be wide enough to mount my custom shift boot billet trim ring to. I will powder coated or paint the trim ring satin black at some point. I'm happy how it turned out. I started with a paper board template. Then I transferred to metal and bent it up (by hand). I just need to bend the top to match the radius of the sides and welded it up. This piece will be bolted to the floor and firewall. I will body work and paint this the satin color that my interior is painted. I figured it would be different than most plus it will aid in laying the carpet as I wont have to go up and over this cover..
Marc
