09-07-2020, 10:56 AM | #1026 |
All about them K’s
Re: Project 68 k10 LWB..aka "The Hulk"
I just skimmed over this build, nice truck! It’s going to be an animal when you get it on the road!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-08-2020, 01:00 AM | #1027 |
That’s funny I assumed the other had one. I will have to look at my sons 70. I will see if it would it and let you know.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
09-08-2020, 01:03 AM | #1028 | |
I can’t wait to get the bed floor and interior.
09-21-2020, 10:34 AM | #1029 |
Hey all I was able to spend some time on tuning the Torqstorm supercharger. Man it sounds cool.
Here is a video after I tuned the new MAF. https://youtu.be/cWadcANsbMU I also received my Smokey road rod shop bed kit. Here it is laid out on my bed rails. Now to drill all the holes and try and game plan how to get this bed assembled.
09-22-2020, 09:18 PM | #1030 |
Roto Reuter thats the name...
Great choice on the bed kit. Right on.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
09-22-2020, 11:06 PM | #1031 |
No special design on the wood? I'm thinking of using these guys for my bed as well and also thinking of having them burn something on the floor. Not sure yet.
The wood looks great. Ready to see this update.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
09-23-2020, 01:09 AM | #1032 |
Bed wood looks nice!
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-23-2020, 10:43 AM | #1033 |
I have been looking for a design but will have it placed on the box. if I can make up my mind. Its like a tattoo you need to make sure!!!!
09-23-2020, 10:47 AM | #1034 |
I was able to get my filler neck and vent tubing routed. I am going to place a vent up higher than the fill neck up under the bed side up above the marker light.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 09-24-2020 at 01:52 AM. Reason: Can’t spell |
09-23-2020, 11:31 PM | #1035 |
I like how you pieced all this together man. What is going to go on the barb here?
09-24-2020, 02:00 AM | #1036 |
Thank you! Well since I cannot get the 5/8” vent line up to the gas cap. I decided to add this vent line and run it above the fill cap. I called Tanks inc and discussed my situation. They said to vent the tank (the 3/8” line) and to add this tee to the filler neck vent. They also said to tee them together and run the one higher than the fill cap. I will try to connect them and run One 3/8” line up and if it doesn’t work I will separate them and run two 3/8” lines.
09-24-2020, 02:02 AM | #1037 |
Hey Dan. Thanks to you! Thank you!
I am working with Frank and Rhonda on the tool box cover. Trying to get something cool.
10-07-2020, 05:39 PM | #1038 |
Continue to work on the bed. I ordered a set of stainless/delrin tailgate trunions.
Figured I would hit them on the polisher before install. Time to get the tailgate installed so I can square up the box and get it tightened down for the last time.
10-07-2020, 09:05 PM | #1039 |
They look great. I bought set while back but can’t find them.
10-07-2020, 10:52 PM | #1040 |
Grabbed a quick picture after getting the gate on. Looks good. I do need to tighten up the slack in the handle. I don’t like it. But the gate is on and looks great.
DW. I say that everytime I need something lol.
10-14-2020, 12:30 PM | #1041 |
Little update on the bed. Tailgate and fender wells are in. I just need to get my toolbox doors installed and aligned so I can tighten all the 1000 bed bolts.
10-14-2020, 12:36 PM | #1042 |
I also finished up my Gas tank filler behind the driver taillight. I ran the wiring for the taillights. reverse lights, and side markers.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 10-14-2020 at 12:41 PM. |
10-14-2020, 02:34 PM | #1043 |
Looking good! Curious. Where did you get the cork gasket for wheel wells? And any chance you have pics of your cross sill in place before the bed wood went on?
EDIT: Oh, and did you use the rubber pads under the cross-sills? .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 10-14-2020 at 02:40 PM. |
10-14-2020, 06:12 PM | #1044 | |
The cross sills are stock but have been customized by me and have been powder coated. I will see if I have a picture. but post 1034 you can see the cross sills
10-14-2020, 06:25 PM | #1045 |
Thanks. I am looking to see your placement of the second to last cross sill on the frame, hoping to see what holes you used in your frame. And I am also wondering if you used those little square rubber pads under your cross-sills or if they are metal to metal. Can't see that in post #1034 unless I am blind lol.
10-15-2020, 12:02 AM | #1046 |
Oh I got you. I measured my mounting holes in my bedsides so I cant remember where i placed that cross sill. I will have to look and get back to you. I raised my sills up 1” so I made my own pads with some real thin rubber. I can’t remember the thickness. But it’s pretty thin like 1/16” or so.
10-21-2020, 11:20 AM | #1047 |
Small update...
Received my bucket seats from the upholster. The photo is them just setting in place. I need to melt holes in the floor to keep the carpet from unraveling. after I set the seats in place my upholstery guy and I set the center counsel/seat in and now have a game plan on how it will be upholstered. The plan is to have the design flow from the center counsel to the speaker box. We will see how that goes.
10-21-2020, 11:26 AM | #1048 |
My time lately has been used up by work and a new toy.
I decided to order a Snap-on welders work station to consolidate my MIG and TIG welders so not to have all these carts. On another note I cant wait to remove the truck and clean out all the dust and debris from all the work on this truck.....bodywork, dust, ash from the forest fires, etc.
10-21-2020, 03:14 PM | #1049 |
Those seats are just plush looking
I like the new welding station too. So you got ash from forest fires eh? Hopefully you and your family didn't have any loss due to all those fires.... .
10-22-2020, 01:15 AM | #1050 | |
I can’t wait to get the center section. I am heading to Montana for 2 weeks so maybe it will be finished by the time I get back!
