Old 10-22-2020, 11:43 PM   #13
cornerstone
cornerstone's Avatar
Re: 'Hay Burner' 69 LWB Frame Off Restore
Thanks for contributing your story and build to the board! I'd bet most builds don't go exactly to plan in general. It seems the at the start of a build everything is just simple job, I was even blind enough to think I would have an LS swap in and done within a couple of weeks. That was nearly 4 years ago. If it were only as easy to put them back together all shiny and new as it is to tear them down when they're all greasy!
Clearly you do nicer work now than when you were 16! I look back at some of my 16 year old "repairs" and have to laugh at myself as well. Like the time I riveted a street sign over the giant hole in the floor board and called it rust repair.
What other plans are in store for the truck? You've already got a super nice set up with a big block and coil overs, but what color do you want?
It sounds like you have an interesting job... care to share what you do in the entertainment industry?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
69 lwb c10, big block, hay burner, my build, restore
