10-24-2020, 01:05 PM | #1 |
Bed tie down options?
Occasionally, I’d like to use my truck to actually carry stuff. I have no way of securing cargo. I’m thinking about adding one of these in each of the four corners. Anyone do anything similar or have a better suggestion? Thanks!
https://www.dccargomall.com/recessed...ing-holes.html |
10-24-2020, 01:21 PM | #2 |
Re: Bed tie down options?
I simply replaced a few of the bedside perimeter bolts with large eye bolts. These can be swapped easily or removed at any time with no damage.
10-24-2020, 02:02 PM | #3 |
10-24-2020, 02:34 PM | #4 |
That's what I did as well, SS eye bolts...I can't take credit for the idea...the PO did the same...I just replaced them recently ...I have 4 in mine...2 at the end near the tailgate and 2 near the head, but not all the way up...I think bolt #2 or 3 from the head...I may do 2 more in the center of the edge...
10-24-2020, 03:09 PM | #5 |
Can you still easily slide sheets of plywood in there with the eyebolts in place on a stepper?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-24-2020, 03:17 PM | #6 |
If you have a fleetside, you could add some attachment points through the inner panel of the bedsides. I used some cheap U bolts and a piece of aluminum on the back side to help distribute any forces from tying stuff down. Basically, I looked at what was in my dad's 02 Silverado and copied it. Drilled 8 holes in the bed, but with everything I've attached to them, the holes were worth it
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-24-2020, 04:31 PM | #7 |
Yes, I measured between eye bolts just to make sure, but it is a little over 48" wide...I had put plywood back there before I started my restoration with no problem.
