Old 08-23-2020, 02:46 PM   #76
factorystock
factorystock's Avatar
Re: Survivor ‘76 Crew Cab
Didn't mean to give the wrong impression on your project, just trying to emphasize how uncommon the base look was in the mid to late 70's. '78 was the end of the era for white painted hubcaps, a tradition that dated back to the 50's. These are the details that make your truck special, something '79 and newer trucks never came with.
factorystock is offline   Reply With Quote
Old 09-17-2020, 01:08 PM   #77
ACS
Still working away. Picked up 2 yards of soil at lunch today.
And the workers unloading it
ACS is offline   Reply With Quote
Old 09-20-2020, 01:45 AM   #78
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by Pontiac1976 View Post
Hum I see that this 76 had the not common per-72 gas peddle. But this one is M/T. all I seen 73-87 have the slanted larger peddle except 3 73 auto's seen in pic's or in yards shows so far. But can say how many M/t had the older style peddle most times did pay to much never how most of the time to them because I had A/T. So you only looked at parts would be the same might be good or you needed around 2005 I want a nice new peddle, ordered new they sent me the wrong one for my 77 the gm bag id: 67-72 and told me that what it had in it. So ever since I pay attention
to the Gas Peddles now. I have a nice used peddle now. OEM 76-72 on parts shelf some where.
Yes your truck great looking, keep up the good work.
Almost all ‘76 trucks I’ve ever seen have the van/car/67-72 skinny gas pedal from the factory. There must have been some kind of transition this year when they went from the wide flat bottom pedal to the slanted pedal. I’ve never known the reason for this.
Old 09-20-2020, 01:47 AM   #79
Corts60
Just here to tinker
Corts60's Avatar
Attachment 2048896
Attachment 2049105
Awesome! Doing what she was built to do!
Old 09-21-2020, 09:23 AM   #80
Pontiac1976
Pontiac1976's Avatar
Smile Re: Survivor ‘76 Crew Cab
I had a 75 A/T that was factory with the fat style gas peddle in Canada North East.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-21-2020, 10:11 AM   #81
Pontiac1976
Looking more at them. I'M thinking that the smaller gas peddle came with the clutch set up to give more space between the peddles.
Old 09-23-2020, 06:28 PM   #82
ACS
I picked up some new rear brake shoes. I’ll spare you photos of a brake job, but while I was cleaning up the backing plates I started looking closely at the axle U bolts
I don’t know what the half ton trucks use, but if you’ve got a 3/4 or 1 ton with the spring plates that trap and hold dirt - check your u-bolts.
I cut one off and had the local spring shop bend me up some replacements.
Old 09-23-2020, 07:04 PM   #83
The Ohioian
When you have the time could you take a pick of the fire wall and how the manual pedal and bell crank come out and or go in the steering column is so close and I Am interested in the bends on the rod. Thanks for the wonderful truck and the photos you’ve posted. Good job on keeping the cash handy to purchase it.. we all know how hard it is when you got a work crew like that.
The Ohioian is offline   Reply With Quote
Old 09-24-2020, 08:25 PM   #84
ACS
I’m not sure if this is what you are after, but from the clutch pedal, the rod is straight down and into a rubber boot that passes through the floor. The steering column passes through the firewall just above it. In the phot below, the clutch pedal arm is in the foreground on the left:
On the engine bay side, the bend in the rod is inside the rubber boot - the boot is right up to the bell crank connection. There appears to be quite a bit of room all around with respect to steering column proximity.
If you want more detail on the bell crank, I can take a few photos from below.
Old 09-25-2020, 09:20 AM   #85
The Ohioian
Attachment 2050601
Attachment 2050602
Thanks it helped me understand so much.
Old 10-14-2020, 12:51 PM   #86
ACS
I discovered that the VIN got typed out wrong at some point on the title. TCLxxxx had been typed as TC1xxxx. I went to the licensing office to figure out how to get it fixed. Not really that big a deal, go to a dealer, have them verify it in writing and bring that back. Got that sorted out, and in the process took the truck back to the dealership where it was sold when it was new. The service manager has an ‘80 he’s in the midst of doing an LS swap in - I think that’s why he took sympathy on me and got me the info I needed for the VIN.
Old 10-27-2020, 12:46 PM   #87
ACS
Hauled 800 pounds to scrap. The local scrap yard also keeps random older vehicles that come in. So after I weighed out I looped back and picked through a few square bodies that were in the yard. Grabbed an OEM crack free taillight lense for $5. Needs a polish, but it will replace one of mine that is cracked.
Didn’t want to park to close - the magnetic claw is always on the move.
Old 10-27-2020, 01:22 PM   #88
burnclown
Nice truck , I see those 8 lug rims and was wondering what size they are? I riding a 77 Suburban K20 and am having a terrible time finding 16.5 tires
burnclown is offline   Reply With Quote
Old 10-27-2020, 01:46 PM   #89
stomper
Junior Member
stomper's Avatar
You have two 16.5" tire choices anymore. Super Swampers or 37" Wrangler military tires. Neither of which you want anyway. Best option in my opinion is get a set of 16x7 Ford van rims. Up to 1996 model year or so. They are cheaper than aftermarket 8" rims and give you a little more width than our 16x6's
"I was patina when patina wasn't cool."
1973 Cheyenne Super SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 10-27-2020, 01:59 PM   #90
ACS
@burnclown Funny you ask, it’s another reason I don’t tread to far into the scrap yard - puncturing a NLA tire. The wheels are 16.5” with an aging set of Transforce tires. I’m going to do the Ford Econoline 16” wheel swap when these tires are done.
Old 10-27-2020, 02:13 PM   #91
ACS
If you don’t need off road tires there are some other options:
The Firestone Transforce are still out there new in 9.50x16.5 as of today at about $170 a tire.
STA - Specialty Tire of America also has some more vintage sizes.
There’s also a tire called “Power King” that pops up online in the 16.5 diameter. It says it’s an all-season radial, but it sure looks like a trailer tire to me.
Old 10-27-2020, 07:45 PM   #92
burnclown
Thanks for the info, I'm going to look into the ford 16's.
Old 10-28-2020, 08:52 AM   #93
ACS
Pay attention when you’re buying them. Some of the E350 vans didn’t come with hubcaps, and the steel rims don’t have the nubs stamped in them to retain hubcaps. If you want to run original Chev/GMC caps you what the rims with the hubcap nubs
Old 10-28-2020, 09:04 AM   #94
MJN
MJN's Avatar
I've run Power King's- they're decent and wear well and had them last quite a long time. They're not just trailer tires. At least the set I had was still made in the USA too.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-28-2020, 11:07 AM   #95
1976gmc20
The thing is that once you swap to 16" wheels you can get tires just about anywhere. Sometimes you ruin a tire and need another one Right Now!
When I bought my 76 C/20 in 1996, the first thing I did was go out to the salvage yard and swap the 16.5" wheels for a set of five 16" wheels with some usable 245/75T16 tires.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 03-21-2021, 11:45 AM   #96
ACS
After 2 pages of hubcap discussion, I’ve finally found a set of the proper white painted GMC’s. They’re a bit rough, but it’s a great starting point.
Old 03-24-2021, 06:11 PM   #97
ACS
Out of hibernation
Old 03-27-2021, 08:39 AM   #98
Greenlee
Greenlee's Avatar
Beautiful truck! Nice score on the hubcaps.
Greenlee is offline   Reply With Quote
Old 04-17-2021, 02:43 PM   #99
ACS
When I got the truck I picked up a new cap, rotor and plugs. I swapped the plugs out at the time, but the cap and rotor ended up sitting on the shelf. I switched the stuff out this morning. I feel pretty bad now for not doing this immediately, I don’t even know how it ran.
I’ve also resealed the thermostat housing/water neck - again. Filed the housing flat and am trying a paper gasket painted with Permatex Aviation.
Old 08-27-2021, 09:48 PM   #100
ACS
So the Permatex on the paper gasket did the trick. Haven’t seen water leaking at the thermostat since I resealed it.
Just been using it. Hauling water & gravel a bunch this season. Just did an 80 mile round trip to the beach @15mpg. Not bad for the SM465 & 4.10.
