11-05-2020, 07:36 AM | #1 |
Re: Pole Frame Garage
I did the plumbing with some help of a buddy. I have a sand mound that is gravity fed from the opposite side of my house. I could not gravity feed from the garage to the house to tie into the system so i had to install a sewage ejector pump. This is the garbage can looking thing that is buried. It has a 4" inlet in the side of it, which is underground. The toilet and all drains tie into this. Once the tank fills and operates the float, the pump turns on and pumps into where i will tie it into my house system and then it will gravity drain like the house is designed. This is an ejector pump, not a grinder pump. it is important to use the correct one. If you have a city sewer, then a grinder pump is fine. If you have a sandmound, you want to use the ejector pump. The grinder pump will basically puree the waste before pumping it. Then your holding tanks that separate your solids and liquid will not be able to hold what used to be solid and you will pass on the solids to your sand, ruining the bed in time. With all that being said, it wasn't hard. I have a 1 1/4" pvc pipe that i am going to pull a 1/2" pex line in for the water supply and a 2” return waste line.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) Last edited by rharris; 11-05-2020 at 10:46 PM. |
