Old 11-07-2020, 08:50 AM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: When I apply the brakes my idle drops too much
How are you setting idle? What screws are you using, the idle mixture at the carb base or the single one at the throttle?
Old 11-07-2020, 09:00 AM   #2
kens65fb
It is a brand new Edelbrock 1906 carb with an electric choke, I am NOT a seasoned mechanic, but I adjusted the (2) screws at the base of the carb, with a vacuum gauge to get the best vacuum.
The screw on the right side seemed to do little, but the best vacuum I could get was 15-16 inches.
Then I set the idle screw to about 900 RPM
kens65fb is offline   Reply With Quote
