![]() Join Date: Jul 2018
Need full pulley set up for SBC / SWP / PS
So motor almost fully together, but as I put it back together I am finding more issues. None of the pumps line up and none of the part numbers match anything in the GM parts catalog. I need the water pump and crank pulley set. I have the correct one for the pump. Need ASAP!
1971 Custom/10 - 350/3 speed, Orange/White roof |
#2 | |
Always on the hunt...
![]() Join Date: Sep 2006
Re: Need full pulley set up for SBC / SWP / PS
Classic, I will shoot some info now. I know the PS pump pulley and water pump pulley are way off, as in not even close to what I need. I *believe* I have good options for the crank pulleys.
Current Crank: 3755820BC 1-groove against balancer 3751232BB 1-groove stamped and 3923898 2-groove cast Water Pump: 3927797AF - Think its a 6 cylinder with no power steering pulley PS Pump: 3770509CE - No idea what this is for I have the manual and think I "might" know what I need but I will defer to your expertise. I have the correct lower PS pump bracket that bolts to the block and the LH engine mount. May have been Grumpy I bought that from or sent me to the correct mount when I purchased it. I verified it then before purchase about a year ago. BTW, don't think it matters, but trying to match it all up on a new Gen 1 GM crate motor. The last one was a debacle of bad mechanics and guys who knew less than nothing hence the 6 cylinder pulley on the water pump that almost hit the balancer and crank pulley. I can get some pics in a couple of minutes, just wanted to get you the info ASAP. I will take what I need, but if you have as a set and don't want to break it up, I will take a matching set.
That should have read none of the Pulleys line up, not pumps...
Classic you are correct.
Just running Water pump, crank, alternator and power steering. No AC at this time, will be adding Vintage Air next summer. Also here is the bracket for the PS pump.
#6 | |
I may have a correct PS pulley inbound. I was able to locate a 3993325 PS pulley and have a 3751232 crank pulley currently. From what I gleaned from a post you made, I believe that is a workable set, just need a water pump pulley to finish it off. At any rate if you can help out on that end or still have a matched set, let me know I am still interested in either option.
Classic, got your message, and thanks to a couple of guys here, I believe I have the right parts coming in in the next week. Once I Hager the pets and verify it all lines up I will make a separate post in the forums for reference as to at least what my parts are that worked and lined up correctly for my by part number. Hopefully that will help some of the future questions for those chasing the ghosts of adding factory power steering to a SBC with a SWP to at least the 71-72 years. As I learned on a phone call with Abe, there are considerations and questions to answered between the years thanks to “engineers”!
