![]() Join Date: Mar 2003
How good are front end urethane bushings?
What are the pros and cons on urethane front end bushings and where can I get them for my 72' 3/4 GMC?Thank you
Merciless Butcher
Pro: Tighter handling, less body roll......Con: They can be squeeky and annoying. Get the ones that are impregnated with graphite. They are alot quiter. Search the net...I'm sure there are plenty of companies that offer them.
Your Bought And Sold....I Got Your Soul! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Your truck uses steel bushings.
The only possible place to use urethane on your trucks front end is the swaybar.
i have been thinking down that same road myself , and chevy duty seems to offer alot of urethane parts for these model trucks. check them out!
#6 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Designated A-hole!
Would that be a good reason to go with a 73 and up front suspension?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#8 | |
Save your money for something else. Everytime I've ever used urethane stuff (mini trucks and street rods), I've been sorry I did. The car always develops more vibration in it. The rubber stuff does good insulating road vibration from you.
Designated A-hole!
I wasn't talking about using poly bushings, I was just wondering if you wore the steel bushing out, how would you replace it?
Just replaced them on mine, they simply unscrew with an impact after removing a-arms. Mine had been installed improperly, there is a tit on crossmember that is supposed to fit into the bushing shaft to locate it properly. I guess PO didn't pay attention. Brian
![]() I HAVE REPLACED THEM ON A FEW TRUCKS, & I HAVE ALWAYS GOT A UPPER OR LOWER CONTROL ARM SHAFT KIT. IT COMES WITH THE SHAFT & THE CAPS OR BUSHINGS. THE ONLY RUBBER ON THEN WAS THE SEAL TO HOLD THE GREASE IN. THEY'RE NOT TUFF TO REPLACE, BUT IT IS A GOOD TIME TO CONCIDER REPLACING YOUR BALLJOINTS. ![]() ![]() ![]()
Designated A-hole!
Thanks, that's what I wanted to know.
I'm working on rebuilding my frontend right now. Does anyone know offhand what size the ends of the upper/lower bushings are? Thanks
1971 GMC LWB 350/350--SOLD 1970 Chevy LWB 350/350--SOLD 2000 VW VR6! |
