Old 11-10-2020, 04:18 PM   #1
EricU
Squarebody Dash Repair -1st attempt
This is my first attempt at a Squarebody dash repair. After doing the usual “research” on different websites and University of Youtube, this is what I came up with.
The materials that I used were:
Canned spray foam
Hardware store mesh
TotalBoat’s FlexEpox (flexible epoxy) after seeing another post
Upol 7061 Flexible High Density Body Filler (Flexible Bumper Filler)
Upol Raptor liner
I pulled this dash out of a Suburban parts rig that I bought a while back. Pretty typical cracked dash, not as bad as some that I have seen.
Since this dash is going into a C30 dually that I am going to sell (I really don’t need two of them) I decided just to do away with the speaker cut outs. I also V-grooved out the various cracks
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 11-10-2020, 04:20 PM   #2
EricU
Re: Squarebody Dash Repair -1st attempt
Bought some mesh material at the local hardware store along with a can of foam. Cut the mesh to size and glued them in place using CA glue.
The CA glue worked very well.
Old 11-10-2020, 04:22 PM   #3
EricU
Foamed it up and left for the evening.
The next day I used a combo of blades and my little grinder with a 3” 30 grit disc to knock down the foam.
Old 11-10-2020, 04:25 PM   #4
EricU
I had high hopes for the Upol 7061 Flexible High-Density Body Filler (Flexible Bumper Filler) and used it on one of the cracks that I had V’d out.
The Upol does sand easy, the problem was that it was too thick and therefore not flexible enough. The dried vinyl adjacent to the flexible bumper filler just cracked away. So I ground it out and used the TotalBoat’s FlexEpox, which did work quite well.
But don't throw away that tin of bumper filler as there is a use for it...
Old 11-10-2020, 04:26 PM   #5
EricU
The flexible epoxy is good stuff but a little more difficult to work with as it has a pretty long setting time. It also stays somewhat viscous and moves around. I tried to level the surface as much as possible, but due to the shape of the dash I had to do it in two application.
The flexible epoxy is more difficult to sand. I used a combination of a sanding block and my DA
Old 11-10-2020, 04:27 PM   #6
EricU
After a couple of coats of the epoxy, I went back to the flexible bumper body filler which spread out very nice.
At this point, if I was planning on covering the dash with either vinyl or leather, I would be done.
But this dash is going to get textured using thinned down bed liner, so I will be doing a bit more prep work.
Old 11-10-2020, 04:28 PM   #7
EricU
The dash insert trim thingy had some scratches so I hit it with some acetone, scuff pads and some sandpaper.
It will get epoxy primed, then base coat and matte cleared.
Old 11-10-2020, 05:24 PM   #8
TKCR
TKCR's Avatar
Wow!! looking good
I find it satisfying to dive into something like this, and then see the before & after pics. Keep them pics coming. Awesome job.
Old 11-10-2020, 09:02 PM   #9
jimboh247
jimboh247's Avatar
I have got to see how this turns out!
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 11-12-2020, 08:44 AM   #10
wixthedog
wixthedog's Avatar
Excellent work! I look forward to seeing how it turns out.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 11-12-2020, 09:19 AM   #11
ChevyMopar1969
Looks good!
ChevyMopar1969 is offline   Reply With Quote
Old 11-14-2020, 10:25 PM   #12
EricU
I didn’t like the corners that I had filled with the bumper filler as they were also cracking adjacent to the filler. So I ground them down and added more foam.
Cut the foam out the next day, ground it back some and added a skim coat of the flexible bumper epoxy.
Old 11-14-2020, 10:27 PM   #13
EricU
I didn’t like the way the VIN window was turning out, so I made this little piece out of 1/8” acrylic that I had and used CA glue to install it.
It is a much cleaner look now.
Old 11-14-2020, 10:28 PM   #14
EricU
A little more DA work with 220 then 320 and a good cleaning and I am FINALLY ready for texture and color.
Old 11-14-2020, 10:31 PM   #15
EricU
Decided that I wanted to epoxy primer first.
First I hit the dash with two coats of SEM’s Plastic Adhesion Promoter and let that flash off
Old 11-14-2020, 10:32 PM   #16
EricU
I then used Upol’s Raptor bed liner reduced down with a little acetone. I added some Beige colorant to the bed liner. Had to hold the gun further away from the piece than I normally do to get the texture that I wanted. Next time I probably wouldn’t reduce the bed liner so much at first.
I am happy with the result.
Old 11-14-2020, 10:33 PM   #17
EricU
After sleeping on it and looking at it the next day, I liked the texture but wasn’t happy with the color.
Luckily I had some SEM Saddle Tan colorant which was a darker brown than I had expected.
Old 11-14-2020, 10:34 PM   #18
EricU
A little more Plastic Adhesion Promoter on the vents and colored them also.
Old 11-15-2020, 12:34 AM   #19
SCOTI
SCOTI's Avatar
Looks pretty decent.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-15-2020, 07:49 AM   #20
TKCR
TKCR's Avatar
I think it looks great! The Saddle Tan for dash, is a Dark Saddle Tan, that’s why it’s darker than the first one. And that’s the way it should be, originally. The Saddle Tan interiors were the lighter saddle, but the dash was a dark Saddle Tan.
And for future reference, there is a vinyl & leather filler. I used it to fill small cracks on a dash. And I used it to repair cracked leather on seats. It does really well. It goes on white and then drys clear. It’s those 2 small jars in the front. I also have the vinyl filler, but it’s not it the photo.
Old 11-15-2020, 09:24 AM   #21
Getter-Done
Getter-Done's Avatar
Nice Job
I have one that looks like yours did.
I like how you did away with the small speaker hole spots.
Thanks for sharing the details.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 11-15-2020, 02:46 PM   #22
Mathew21
Mathew21's Avatar
Nice work, Thanks for sharing.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 11-15-2020, 11:58 PM   #23
Factory Guy
Factory Guy's Avatar
Really nice job!
Factory Guy is offline   Reply With Quote
Old 11-16-2020, 12:34 AM   #24
EricU
Thanks TK and everyone else. Like I said, I am very happy with the way it came out.
I like the finish as it looks more modern with the fine texture without looking out of place. I hope to play around some more with the finish on my test panel and may try just knocking off the very top with some 800 grit.
Yeah, my dash that this one is replacing is the Darker brown/tan. When I purchased the quart of the SEM color coat, I meant to get the lighter tan color but ordered it just by name and did not check the color card - It was a mistake but a lucky one at that. I have since ordered up a SEM's color card for future orders. BTW, I get my SEM products from 66 Auto Color - Great folks to work with
I still need to finish up the horizontal trim bar, then install the dash.
Then onto the door panels, at least I know that I have the materials and process.
Old 11-16-2020, 12:44 AM   #25
EricU
...And for future reference, there is a vinyl & leather filler. I used it to fill small cracks on a dash. And I used it to repair cracked leather on seats. It does really well. It goes on white and then drys clear. It’s those 2 small jars in the front. I also have the vinyl filler, but it’s not it the photo.
TK, how flexible is that Leather filler?
How thick can you apply it with it still be flexible?
Thanks for the tip!
Last year, I redid the dash pad from my '65 Caddy Drop Top. The original pad was so dry that it kept cracking. I tried using regular body filler which was way too rigid, then I tried Polyvance's 2050-9 Padded Dash Filler which also dried too stiff.
I ended up stripping and re-foaming the entire dash pad. Which I did not want to do with this truck
