Old 11-11-2020, 06:36 AM   #1
Larry S
Larry S's Avatar
Ls manifolds/ headers
I have a 72 c10 frame with 6.0 /4l80e combo sitting in it. I used ingenuity fab and speed 67-72 mount and crossmember kit. Does anyone know what manifolds or headers will clear and not interefere with dipstick tube or spark plug wires?
Larry S is offline   Reply With Quote
Old 11-11-2020, 07:28 AM   #2
notsolo
notsolo's Avatar
Re: Ls manifolds/ headers
Look in the build section "71 LS Stepside ".....I think he used speed engineering headers....shoot him a msg ask how the fit?
notsolo is offline   Reply With Quote
Old 11-11-2020, 08:23 AM   #3
hugger6933
Trailblazer SS Should fit they also made a TB without the SS that had a 5.3 that carries same manifolds. They are still available new. Jim
hugger6933 is offline   Reply With Quote
Old 11-11-2020, 08:43 AM   #4
A1971Blazer
A1971Blazer's Avatar
2010 Camaro manifolds with heat shields removed and smoothed up
will be sending them to be jet coated soon
plenty of clearance and years of leak-free, trouble-free operation on 2001 5.7 LS1
Transmission and oil level dipstick fit perfectly
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-11-2020, 10:20 AM   #5
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Speed Engineering long tubes is what I am running with the same set up. I'm sitting on POL engine stands, but you won't have issues. You will have to trim the ears on your transmission bell housing. You can look in my build thread to see them.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-11-2020, 10:45 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I used the Hooker Cast Iron headers/manifolds in the pictures below on my '67 Panel Truck with an LS1. Cleared everything with no problem. I bought them off of E-bay.
It looks like these might be about the same and on sale..
https://www.holley.com/products/exha...st%20Manifolds
You have to watch that price. That is per manifold. I don't think I have ever seen anyone sell them one at a time....... Any way it automatically added 2 to my cart. Dunno.
LockDoc
Leon
Old 11-11-2020, 11:32 AM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ls manifolds/ headers
I used the S/S headers for a late model Camaro.
Here is a link with them and some others.
"Stainless Work Headers"
http://67-72chevytrucks.com/vboard/s...d.php?t=695713
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-11-2020, 11:42 AM   #8
1971Stepside
Almost Satisfied
Not the greatest pictures, but all I have on my work PC. If you need to see anything else let me know. I'll look for a shot of the trans where the header goes by.
Old 11-11-2020, 08:40 PM   #9
Larry S
Larry S's Avatar
Is this the ones you have? What exactly are you talking about cutting off transmission? Thanks
https://www.speed-engineering.com/featured-products/ls-conversion-swap-headers-camaro-chevelle-nova-c10-truck.html
Old 11-11-2020, 11:05 PM   #10
chev-obsession
chev-obsession's Avatar
I used 2010 Camaro manifolds and they fit great. Used with an F body oil pan and dipstick
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-12-2020, 10:28 AM   #11
1971Stepside
Almost Satisfied
Larry, here is what I have.
https://www.speed-engineering.com/ls...2-ls3-ls6.html
The ear on the passenger side of the 4L80e has to be trimmed down to clear the long tube header. If you go with the shorty header in your link then you don't need to modify the transmission.
Old 11-12-2020, 06:41 PM   #12
Larry S
Larry S's Avatar
LockDoc
I like these! Thank you.
Old 11-12-2020, 07:54 PM   #13
MDPotter
MDPotter's Avatar
I used Speed Engineering's shorty headers with my 6.0/4L80 combination and had to trim the ears on the trans.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-13-2020, 08:30 AM   #14
Larry S
Larry S's Avatar
Man your build looks awesome! Question, if I cut ear off bellhousing, does that mean I can't put dust cover over torque converter? Thanks.
Old 11-13-2020, 11:31 AM   #15
Rich84
Rich84's Avatar
You can still use the dust cover.
Trailblazer manifolds..Had to cut.
Rich84 is offline   Reply With Quote
Old 11-16-2020, 10:50 AM   #16
verdell
verdell's Avatar
Just installed these on my Brother’s 66 with Fbody oil pan and EBay mounts. From Summit and fit like a glove..
verdell is offline   Reply With Quote
Old 11-16-2020, 10:51 AM   #17
Larry S
Larry S's Avatar
Originally Posted by verdell View Post
Just installed these on my Brother’s 66 with Fbody oil pan and EBay mounts. From Summi and fit like a glove..
Are those the holleys?
You have a summit part #?
Old 11-16-2020, 03:59 PM   #18
Larry S
Larry S's Avatar
Is this them
Old 11-18-2020, 01:42 PM   #19
verdell
verdell's Avatar
Originally Posted by Larry S View Post
Is this them
Yes, those are the ones. They also come in ceramic coated as well. We're doing two more swaps this winter and will be using these again.
Old 11-19-2020, 09:21 AM   #20
rustycars63
Has anyone 1947-1953 chevy truck used the Summit cast iron manifold with 5.3 and had any luck with clearance issues ?
rustycars63 is offline   Reply With Quote
