![]() Join Date: Sep 2020
Shop truck
I have been transplanting an LS1 and t-66 into my 65 c-10 short wide for a “shop” truck. Saw lots of great information on this site about various aspects of upgrading our trucks. I used an 86 front end to get discs and p/s, Captain Fabs bracket was a big time saver. When I learn to post pics, I will put some up....
![]() ![]() ![]() Join Date: Jan 2018
Re: Shop truck
Welcome to the site!
Here is how you can post attachments -> http://67-72chevytrucks.com/vboard/s...d.php?t=712252 Also, check out the FAQ section for any other site related questions you might have. You can also pm any moderator or team member about any questions if the FAQ threads don't answer it
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: Shop truck
Welcome to the site. I look forward to seeing your truck!
Moderator
![]() ![]() Join Date: Aug 2011
Re: Shop truck
What's a short wide?
Re: Shop truck
It's Better With Nitro
Re: Shop truck
Welcome! I also built mine as a shop truck. I look forward to your pics.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
This is what I started with, bought it for the body, power train was just a bonus....obviously missed a step in the pictures dept
Re: Shop truck
Trying pics again
Re: Shop truck
Heading into shop for new power train
Re: Shop truck
Very nice!
Moderator
Re: Shop truck
I sure like the looks with those chrome wheels.
Re: Shop truck
Those chrome wheels are going away, changing it to 5 x 43/4..between the second and third pictures, I swapped in an 86 front suspension to get discs and pwr steering, used POL upper and lower tubular A arms, built my own upper mount to go to coilovers
Re: Shop truck
These are the mounts, ...
All 4 wheels will be for sale eventually, not sure what I will end up with, have early vette ralleys on it for now |
Re: Shop truck
That's one hell of a "shop truck" lol. Very nice man.,
1966 Chevy C-10 350 Engine 700R4 |
#15 |
Re: Shop truck
The engine ready to go in, some of the mounts I built to carry it. My friends here joked that the transmission x member was for a duramax.... I told them I just used materials I had on hand, no need to run to town for little bit of steel, made some brushed stainless covers for the ugly rubber onthe motor mounts....much more gratifying to build this stuff than buy it, gives me something to keep my hands busy
#16 |
Re: Shop truck
I agree with your friends. That transmission ain't going anywhere
![]() Sometimes there's more fun in building stuff yourself rather than purchasing it from someone else. Great work!
#17 |
Re: Shop truck
My altitude adjustable air cleaner/ maf sensor support, lot of leverage on one clamp at the throttle body
#18 |
Re: Shop truck
So I’m wiring in the cab today, doing some preliminary layouts, checking stuff and bam, it hits me, there are no courtesy light switches in the doors...., so much for the fade switch on the courtesy lights to shut them off.....
#19 |
Re: Shop truck
You can buy courtesy lights... American Auto Wire sells some as does Painless ...and you could always retrofit some in...
#20 |
Re: Shop truck
I bought a used harness from a 67-72 truck and it plugged right in. I did make some modifications to it though to add XJ Cherokee courtesy lights under the dash
#21 |
Re: Shop truck
Yes , i am well aware of those, have two sets in stock in my electrical supplies, just totally spaced it thinking there were door switches 😂, the older trucks I have done had none, just thought this “newer” truck would have them, just finished a 65 Chevelle, it had them, but I was surprised that the same year truck had none..I’ll have to see how anal I want to be with a shop truck
#22 |
Re: Shop truck
I'm so glad I added them to my truck. I love opening the doors and being able to see the floor now rather than complete darkness when I open the door
