Re: Rotten 66 Farm Truck Build
The cab was taking up too much space in my garage, so I decided to start cleaning it up for paint. I took everything out of the cab, including the dash. BTW, that thing had close to 40 spot welds! The reason I took the dash out was to clean up some rust that had start on each side where it bolts up. I debated on what to do with the bottom of the cab and ended up using the same paint I used on the frame.
And here is where I'm at today. Over the last two weeks, I've sank more time than I'd care to admit into bodywork.I prepped the job with a little body filler and scuffing the factory paint. I started with a base of epoxy primer. Then two thick coats of high build 2k primer. I then moved to glazing putty to any defects that went to metal when sanding the high build. I then sealed it with a reduced coat of epoxy before laying color. I did two coats of base, which is a blood red from Custom Shop. Finally, I cleared it with two coats of AkzoNobel 4.0. I'm clearly not a painter as it has some orange peel but it should clean up nice after I cut and buff it. I'm happy with it so far.
Thats looking great, and the fastest colour.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
Thanks Grizz. I'm digging your fleetside. I'd love to stumble upon one and convert this one to fleet before I get too much time and money invested into the stepper bed.
66 Build Thread- https://67-72chevytrucks.com/vboard/...d.php?t=814582 |
60-66 Nut
Brand new fleetside beds are available any the reviews are good on them. You are well on your way to a very nice truck.
Great build so far and Great year of truck! lol The color is spot on! I will be watching of updates
As for the fleet side... i have bought complete beds from Classic Industries and had really no issues and will be again this year. Figure $600 per side delivered if you catch it on one of CI's 30% off sales. They change almost every Sunday. then get a tailgate at somewhere around $350 or so and then a front at about $150, then figure out the bed, wood or steel and go from there. Either way, it will be a nice ride. I am a HUGE red and black fan! My "66 is going to be Flat Red and gloss black highlights. |
Yeah I'm still thinking on the bed situation. It will be the last body section I tackle so I have some time to do a little research.
