Old 11-17-2020, 06:53 PM   #1
xs-cash
Turbo 200r 4 identification
I’m looking at a 200R4 tranny , it has a ID tag that says HC F , any idea what type of car it came out of ? I tried to search , but no luck.
xs-cash is offline   Reply With Quote
Old 11-17-2020, 07:13 PM   #2
hugger6933
Re: Turbo 200r 4 identification
Duh, early to mid 80's GM. Sorry No help I coudn't resist. Good luck. Jim
hugger6933 is offline   Reply With Quote
Old 11-17-2020, 07:37 PM   #3
gmc684x4
S10 had them not sure about hcf
gmc684x4 is offline   Reply With Quote
Old 11-17-2020, 11:26 PM   #4
Sheepdip
Sheepdip's Avatar
This may help you:
http://web.archive.org/web/200701281.../thm2004r.html
Sheepdip is online now   Reply With Quote
Old 11-18-2020, 08:20 AM   #5
hugger6933
S-10's Never came with them, and never is a dangerous word. The S-trucks had 700R4, or in the first two [ I think model runs] TH125C [three speed]. I have had at least one of every year model S truck That used to be my thing along with the full sized Chevy trucks from then but I always said the S trucks were my bread and butter. This thread makes me sound jerkish and that isnt me, or at least I dont think it is.
Old 11-18-2020, 08:22 AM   #6
hugger6933
Monte Carlo SS is the best to find but that is plenty rare. The 200R came in Regals And most all G body cars and intermediates from the General. There are even some dual pattern meaning they will work on just about anything GM
Old 11-18-2020, 09:51 AM   #7
old51sedan
old51sedan's Avatar
From what I understand is they are made to fit most GM products including chevy, Pontiac, Oldsmobile, Buick, etc. The one I just installed in my truck came out of a 86 full size chevy wagon. The ones that were installed in the 442's, Monte Carlo SS, GTO, etc. were the same as regular cars, but have a beefed up valve body which could be installed in any of the 200-4R's. They are getting a little had to come by, especially the muscle car ones. Unless your going to beat the hell out of it, it shouldn't make any difference.
old51sedan is offline   Reply With Quote
Old 11-18-2020, 12:03 PM   #8
Sheepdip
Sheepdip's Avatar
Yes they have been hard to find for a while, I searched craigslist religiously for about a year before I found one. Have not installed it, just stashed for now, plan is to put it in my 40 Ford Coupe eventually.
Old 11-18-2020, 06:20 PM   #9
SCOTI
SCOTI's Avatar
They are the popular g-body platform OD trans as mentioned. Strength wise (stock) they're similar to a 700r4. Their benefit is in the gearing. The 1<2 gear split is closer to a TH350/TH400 vs. the 700r. OD is a little more aggressive as well (.67 vs. .70).
The MCSS, Olds H/O's, & GN/T-Type Buicks did have a specific valve body & stamping to make them easier to spot but I don't recall what it was & doesn't make much difference if you're upgrading for an aftermarket/different drivetrain. Easy to spot them though as the pan is long & has 16 or 17 bolts (I don't recall which it was).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-18-2020, 11:29 PM   #10
xs-cash
Plan on putting it in my 72 1/2 to ,stock 350 with 3:08 rear
Old 11-19-2020, 01:35 AM   #11
SCOTI
SCOTI's Avatar
That's going to be super tall gearing for OD speeds. What tire size are you planning for on the rear axle?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-19-2020, 08:29 PM   #12
xs-cash
235/75 /15 tires , totally stock truck
Old 11-19-2020, 11:37 PM   #13
SCOTI
SCOTI's Avatar
Thats 1685rpm @ 65mph & 1800 @ 75mph.
A 60's-80's sbc in a C10 is going to need 22-2400rpm for the 'sweet' spot.
3.73's would yield about 2200rpm @ 75mph.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-20-2020, 01:39 AM   #14
xs-cash
I just want to be able to drive it on the highway and not be screaming rpms
Old 11-20-2020, 11:39 AM   #15
SCOTI
SCOTI's Avatar
With that auto trans/gearing & tire height, you'll need more rear gear.
People assume that 1600rpms = better for driving but sbc's/bbc's have a happy spot slightly above 2krpm. That needs to be the target. Even the later LS/automatic combos are set-up to achieve over 2krpm @ highway cruise speeds (manual trans cars are geared differently).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
