Old 11-16-2020, 10:54 AM   #1
EricSean
6L80 shifter recommendation
I'm installing and L83 with a 6L80 trans and trying to figure out a good shifter to use. Any ideas would be helpful.
EricSean is offline   Reply With Quote
Old 11-18-2020, 10:13 PM   #2
396ci
396ci's Avatar
Re: 6L80 shifter recommendation
my buddy just did a c10 with a lokar ES6L80GM floor mount unit. it is set up to work in 2 modes. has normal operation but move the shifter right and it operates like a paddle shifter with the module installed, just tap shifter up or back to select gear. good luck.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 11-18-2020, 10:20 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Moved thread for more exposure.
Old 11-19-2020, 06:27 PM   #4
EricSean
Thanks. I was thinking about that shifter. Would you know what style and length lever he went with?
Old 11-20-2020, 07:33 PM   #5
LS short box
I used a Lokar floor mount shifter in 68 C10 LS/4L60E swap. It uses the rod directly from the shifter to the trans lever. I was concerned it might have some vibrations going down the road but it's dead still. I have Lokar cable type in my 98 Wrangler LS/4L60E swap and it also works very well. I choose the rod type from Lokar because it's a bit cheaper than the cable style.
Old 11-24-2020, 11:29 AM   #6
EricSean
What length lever did you go with and what bend?
