Old 11-22-2020, 09:02 AM   #1
frenchy51
frenchy51's Avatar
1979 C10 Scottsdale trim
I'm getting ready to repaint my 1979 Diesel (yes it still runs) Long Bed C10 with the Scottsdale side trim. I can see where mine goes from the faded paint-but it's long gone. I can't find reproduction side trim anywhere. Does it exist? Thanks
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 11-22-2020, 09:23 AM   #2
TKCR
TKCR's Avatar
Re: 1979 C10 Scottsdale trim
Like this?
http://www.mar-k.com/Catalog/index.aspx
Old 11-22-2020, 09:39 AM   #3
frenchy51
frenchy51's Avatar
Originally Posted by TKCR View Post
That's not the same trim-I'm looking for the single Spear wide trim. I believe it was the trim option for Scottsdale. In my pictures you can see where some of the adhesive is still there. It was a stick on with no holes. 3M makes a universal stick on trim that's close but it doesn't have the spear point for the front... Thanks for the reply though!
1977 GMC HeavyHalf
Old 11-22-2020, 09:33 PM   #4
Pontiac1976
Pontiac1976's Avatar
If that the trim your looking for, it's after market or it the 81-87 black too way tape style Rubber/ Plastic Trim could be chrome or body color black textured. Chrome was the most seen. Check out 3M there is two other companies to see the option you can get
( body side trim two way tape.) OR E-bay, amazon, autobody supply shops, dealer, or dealer body shop
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 11-23-2020, 10:31 AM   #5
1977ChevGMCK2025Fan
Spear points show up on eBay often. I believe that trim is available at most truck restoration catalogs as well.
1977ChevGMCK2025Fan is offline   Reply With Quote
Old 11-24-2020, 07:22 PM   #6
bhc41051
bhc41051's Avatar
This is as close as I could find. I found NOS ends on eBay fairly cheap. https://shop.advanceautoparts.com/p/...002/10596949-P
bhc41051 is offline   Reply With Quote
Old 11-24-2020, 07:30 PM   #7
frenchy51
frenchy51's Avatar
Are the rear ends in the picture the ones you found on EBay? What did you do for the front pointed end? Thanks for the help!
1977 GMC HeavyHalf
Old 11-24-2020, 07:53 PM   #8
frenchy51
frenchy51's Avatar
Just found square and spear ends NOS on EBay-Thanks for the tip!
1977 GMC HeavyHalf
