Re: Build Date
Would it make sense to have a single unified thread for S/N - dates. ???
I'm trying to find builds close to my 71 to verify build month: 1Z622515
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck. Last edited by Carl Spangler; 11-25-2020 at 08:01 PM. |
All about them K’s
![]() Join Date: Jun 2014
Re: Build Date
If we could keep it on track I think that would be a great idea personally. If those with known build dates could post the build sequence of there vin and the plant. The only problem I see is after several pages it will be a pita to search thru.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#3 | |
Re: Build Date
All new S/N-date entries would be added to each years list.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck. |
![]() ![]() ![]() Join Date: Oct 2015
Re: Build Date
This is the info I have on my build date. My truck is a GMC, so my info might not help much. VIN xxxxx-Z120204
From build sheet: job 01069, scheduled no. date 03-29-71 Blue door tag: mfd 4/71 If I understand correctly, my truck's job number was created on 03-29-71 and the truck was built and completed in very early April 1971. Looks to me like the 20204th GMC truck built at Fremont for 1971 model year.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
![]() Join Date: Jul 2018
Re: Build Date
Carl, I have a 71 C10 built in Fremont plant. VIN is Z603538 and the blue sticker says built 08/70 if that helps you. I also found stamping on the passenger floor pan behind the inner fender that read 8121970 making wonder if that meant the floor was built on that date or if it was just a part number or hidden build date.
1971 Custom/10 - 350/3 speed, Orange/White roof |
