#1 | |
![]() Join Date: Dec 2013
Re: muncie conversion
![]() you can see the "tight" fit of the Muncie trans into the 67 bell housing by the paint removed when I was mocking up mine .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
you can probably find a used 5 speed and make it all fit cheaper with less time than using a Muncie , I wanted this set up because it's close to what the "fast cars" were using back in the 60's early 70's . I'm trying to keep this a 67-72 a period build with No computers /injection systems or custom parts that weren't available back then . you know back when you needed a timing light and a screw driver to change the tune and not a computer or metric tools .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-28-2020 at 12:20 PM. |
I didn't like the idea of leaving the Muncie hanging off the bell housing , So after talking to 2 different Muncie builders I decided to add the tail shaft trans mount and cross member . I did a little massaging to the cross member to have it sit right . Also I was watching some of the Chip Foose C-28 build videos and noticed he added a tail shaft cross member on it under his 5 speed so he's running engine mounts / bell housing mounts and the tail shaft mount on it . If it's good enough for Foose it's good enough for my truck .
![]() https://www.youtube.com/watch?v=zgtmBmzPKOE
