Old 11-28-2020, 02:58 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Check this K5 out
Some sort of advertising campaign going On there I suspect. Lacks rosette rivets for the VIN tag and the RH door isn’t from a K5. I suppose originality isn’t a big factor for an interested buyer though. A lot of work went into the build it seems.
BAT: https://bringatrailer.com/listing/19...let-blazer-27/
Old 11-28-2020, 06:09 PM   #2
hemi43
hemi43's Avatar
What do you look for to tell if its a Blazer or truck door? spot welds?
hemi43 is offline   Reply With Quote
Old 11-28-2020, 06:58 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
K5s for 70-72 had reinforcement plates around the door latches. Sort of a corner shot of one here: http://67-72chevytrucks.com/vboard/s...06&postcount=6
69s didn’t have these reinforcements. I can’t recall if 69s had the screw under the vent window or not.
I don’t see the Blazer for sale having a reinforcement plate. I suspect it’s an aftermarket door. It won’t detract from the ride obviously but noteworthy imo for valuation.
Old 11-28-2020, 07:25 PM   #4
Thealien
Thealien's Avatar
It could also be a cut down truck door that they didn’t install a reinforcement plate on. I have an NOS drivers truck door that I intend to cut down for my blazer and install the reinforcement plate. From what I’ve read they didn’t make a separate door for the Blazers they actually cut truck doors for the Blazers and it is shown that way in the assembly manual but I could be wrong.
Old 11-28-2020, 07:47 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Could be. I think that’s exactly what GM did. There’s some factory literature on cutting down the pickup door.
That linked photo above is from a longer thread on cutting a truck door down: http://67-72chevytrucks.com/vboard/s...06#post2526006
Old 11-30-2020, 01:48 PM   #6
69TowRig
69s do not have the screw.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
