![]() Join Date: Feb 2016
Re: The build date project
I have a couple of build sheets that I have collected over the years but no truck to go with them, would they help?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Apr 2005
Yes, absolutely they would help HO455
All about them K’s
![]() Join Date: Jun 2014
Yes as geunther said, they don’t have to be currently owned trucks at all. If you’ve got a verified build date for a vin, post it up.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Of the 3 sheets I have only one is complete enough to help.
All about them K’s
Thank you sir, added to the top list!
![]() Join Date: Jan 2018
Hopefully, this is what you're looking for.
The build sheet is from my '72 GMC 4WD short stepside truck. I found it under the seat stuffed in the springs. The blue tag, and sales order is from my '72 GMC Jimmy. I hope they can help you. Pat |
Very helpful. I added the Jimmy to post 2 but could not see the numbers well enough from the build sheet on the short step side. I am sure we will settle on one list (post 1 or post 2)but for now we are ironing out the bugs. Like 57taskforce said, adding Jimmys/Blazers might confuse things somewhat.
#8 | ||
![]() Join Date: Sep 2003
I think the blazers and suburbans should be mixed in with the other serial numbers (and maybe noted in parentheses as you have been doing). It appears to me that every model was mixed together as it came down the assembly line. Any proof otherwise? You guys are doing a great job compiling and laying out the info, but I'm going to nitpick a little (it's the engineer in me): -Fremont is spelled with only one "e." -Under each year and make, I think we should keep the list sorted purely by serial number, not by date. ie. Don't intermix 2F1 with 2F3. Sorting by serial number I think will make it easier to look up our build dates in the future when our list is bigger. Regardless, I'll be looking for more data points to add! |
#9 | |
![]() ![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
