Old 12-01-2020, 07:45 AM   #5
Zippi
Zippi's Avatar
Re: *Fuse Block ID*
Originally Posted by PDW HOTRODS View Post
You would be better off making one, it would look better too. I would get some plastic sheet about 1/8 thick and make a flat cover with 4 sides bent like a shoe box lid. You could heat the plastic to bend it or cut and glue it together. then build up and glue magnets under the back side over the bolts and stick it to the heads of the bolts holding the fuse box to the truck. Sheet metal would work too but could spark if too close. You could cut holes in it over the flasher units.
Thanks for the info. Your avatar is not showing up.
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
