Old 11-29-2020, 10:24 PM   #1
Todd46
62 engine angle issue
Hey all, I need some help! I'm mocking up a V8 for my 62 C10 and the engine angle seems way too steep. I measured it at 12 degrees. I'm using the 67-72 engine perches with a 1/4 inch spacer on top of the frame. Transmission is attached and in place. Maybe I need to try a different mount? Feeling kinda confused.
Todd
Todd46 is offline   Reply With Quote
Old 11-29-2020, 10:54 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 62 engine angle issue
I think you need different mounts.
Maybe the 60/66 Guru's can help with the correct mount.
Here is the flip for ya/ on the pictures.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 11-29-2020, 11:09 PM   #3
Todd46
I think so.
How do I flip the pictures? Can't figure it out and everyone keeps doing it for me!
Old 11-29-2020, 11:19 PM   #4
Getter-Done
Originally Posted by Todd46 View Post
I think so.
When you save the picture to your computer.
Always edit your picture with a small(crop ).
Then click the (preview post) button
before you submit post.
Hope this helps.
84 Chevy K-20
Old 11-30-2020, 01:53 AM   #5
AcampoDave
AcampoDave's Avatar
To me the perches look good. I'm wondering about the tranny mount....what do you have for that?
AcampoDave is offline   Reply With Quote
Old 11-30-2020, 02:43 AM   #6
SkinnyG
SkinnyG's Avatar
What is the pinion angle? If it's close to 12° pointing up (maybe a degree less?), you're probably good. The angle of the engine/trans and the angle of the pinion need to work together.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 11-30-2020, 10:56 AM   #7
mongocanfly
mongocanfly's Avatar
12deg is wayyyyyyy to much...needs to be around 3 deg down...and diff needs to be matching angle, but up...
I'm not familiar with your yr models and what it takes to install a v8..is using the 70s mounts a common thing to do?..
They look awfully high to me..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-30-2020, 11:05 AM   #8
mongocanfly
I did find this old thread on it, so I guess the 70s mounts do work..
http://67-72chevytrucks.com/vboard/s...d.php?t=497634
According to Mark's post you may need a diff trans crossmember
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-30-2020, 11:37 AM   #9
SkinnyG
SkinnyG's Avatar
The engine in my '77 C10 is 5° down, which at a lowered ride height, it actually too much for the u-joint operating angles to work with the pinion angle.
Old 11-30-2020, 08:28 PM   #10
Todd46
I have a transmission crossmember from Capt. Fab
I'm wondering if the trans mount is too thick? I did see a lower profile one.
Old 11-30-2020, 08:29 PM   #11
Todd46
When I measured the drive line before taking it out I was at 4 degrees.
Old 11-30-2020, 11:00 PM   #12
Captainfab
60-66 Nut
The rear of the trans needs to go up, or the engine needs to go down. If that trans crossmember isn't going to work, let me know and I will send you one that does.
Old 11-30-2020, 11:03 PM   #13
Captainfab
60-66 Nut
Are those engine mount brackets for a '67-'72 with a small block?
Old 12-01-2020, 09:24 AM   #14
Todd46
Yes they are. I will see what adjustment I can make with the transmission.
Old 12-01-2020, 01:21 PM   #15
62bagger
62bagger's Avatar
I had the same issue when I mocked up the engine in my 62. I used 67-72 mounts and it made fit much better. The motor sits at 3degrees. Hope this helps.
62bagger is offline   Reply With Quote
