Old 12-02-2020, 10:21 AM   #10
68Stepbed
68Stepbed's Avatar
Re: Hard lines from proportioning valve to frame
Bend your own for a cleaner look.
Or, if you're feeling froggy, install -3AN braided stainless flex hoses to a bracket on the frame and connect the existing lines via bulkhead adapter fittings.
Not the same master/pv setup, but this is how I bent my lines. If I was more talented with a bender, I would've done 90 deg bends to the firewall, and ran them flush to the firewall.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
