Old 12-02-2020, 09:54 PM   #826
chewychevy67
Re: 67 GMC super custom build
I trimmed the lip on the Honda seals and this is how they look. I am ok with this. If you put the seal on a bigger table and cut it smoothly throughout the whole seal it looks good.
chewychevy67 is offline   Reply With Quote
Old 12-02-2020, 11:01 PM   #827
TA_C10
TA_C10's Avatar
Nice job. They look good from the pic but hard to see the details on it. That and the squarebody was distracting my focus
I am gonna try that on the set I have. You just use a razor blade knife?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-02-2020, 11:23 PM   #828
chewychevy67
I just used a thicker blade (1") olfa knife so it didn't flex. Just have to be real smooth and it will look very good. If you cut too deep you will hit metal. This was my 1st one. I'll have to get another passenger side and do it again. You have to learn somewhere I guess.
Old 12-02-2020, 11:27 PM   #829
chewychevy67
This is my next project as I'm waiting for metal work. I'm going to take new t3 headlights and split them and put the faces on the newer rear cases. Just another stock looking detail I would like to have. https://www.hotrod.com/articles/1006...ide_front_view
Old 12-03-2020, 11:26 AM   #830
1971Stepside
Almost Satisfied
1971Stepside's Avatar
That turned out much better than I imagined it would. Nice work
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-08-2020, 06:29 PM   #831
chewychevy67
This is probably the most useless option in the catalog of gm parts from that era but it is rpo CE1. Headlight washers. Came on Chevelle corvette and Camaro and probably anything else gm made. I wasn't going to add this but I got bored so I'll figure out how I'm going to make this work. The absolute only option I don't have that I tossed around is V75 liquid tire chain. If I could find a complete set up of that I know how I would make it look stock but good luck finding it anywhere.
Old 12-08-2020, 07:30 PM   #832
IronCanine
I'm trying....
IronCanine's Avatar
100% on brand. I love it.
IronCanine is offline   Reply With Quote
Old 12-14-2020, 03:08 PM   #833
chewychevy67
I added these door harness grommets from a 66 buick to pass the wires thru the door to my panel. Looks clean and keeps it era.
Old 12-14-2020, 05:44 PM   #834
chewychevy67
Passenger side. It just barely clears the motor. The vent window frane sits quite a bit away from it. This sideshows better from the inside
Old 12-15-2020, 07:17 PM   #835
TA_C10
TA_C10's Avatar
Oh, wish I knew about those a year ago!!! Dang.... Very nice.
"It's only money".
Old 12-26-2020, 02:43 PM   #836
chewychevy67
Trying to get the dual air cleaner set up properly and moching up some other small stuff before the metalwork starts. I thought this looked cool. Kind of like a real life exploded view.
Old 12-26-2020, 04:12 PM   #837
IronCanine
I'm trying....
IronCanine's Avatar
Dave Kindig is working on a convertible C-10...maybe a '67. I think it's going to be the season finale. Looks like you've got him beat. I doubt his will have headlight washers.
Old 12-26-2020, 05:08 PM   #838
chewychevy67
LOL. Everyone wants a C10 Vette it seems. I wish I had his team and cash flow to do a build. It would Be a blast. Here is what I figure on the air cleaners. I wish I could find the original hoses in good condition. That will be tough. I'll probably spray these to look like the rubber ones used original. It's as close as I can find with a smooth inner wall and heat resistant.
Old 12-28-2020, 07:19 PM   #839
chewychevy67
Not that I really want to get another decal project going, but I'm happy to help if it doesn't come off cleanly. You know I like this project.
Take careful measurements before you attempt removal...that's always helpful. If there is not a good reproduction version currently available, it shouldn't be a particularly difficult one to do (if you want).
Ha. The other one came off clean but the one on my air cleaner is already destroyed. I have a picture of the air cleaner decal with correct number here. Any chance you could make it? I have another here but has a corvair part number on it. I could send you the repo I have with the different part number on it for correct sizing if you need.
Old 01-01-2021, 12:40 AM   #840
chewychevy67
I hit a snag with my headlights. The octane housings that I have are not big enough to accept the face of the T3 lenses. This thread has the same problems. https://www.jalopyjournal.com/forum/...ights.1209713/. I don't want to wreck the octane lights so I'll look for hella's that will accept the t's lenses as he did and sell the octane lights. Also the headlight bezel won't have enough room to put both headlight washers on the upper part of the low beam so I'm not sure if I'm going to put one on top and bottom or one on high and one on low.
Old 01-01-2021, 11:08 PM   #841
Z10
Z10's Avatar
I used these for my LED conversion. Not T3 faced but the look is pretty original.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-01-2021, 11:48 PM   #842
IronCanine
I'm trying....
IronCanine's Avatar
PM sent...sorry I missed this when you posted it.
Old 01-02-2021, 12:01 AM   #843
chewychevy67
I'll return your pm shortly. First look with the fog lights. The bulbs I have came with a high/ low setting like a headlight. I never realized that. I may use one setting for fog and 1 setting for cornering lights like Cadillacs have. The turn signal switch I have in my telescopic column has this feature built in so it would just need to be wired.
Old 01-03-2021, 02:23 AM   #844
Kronald_70GMC
Kronald_70GMC's Avatar
Wow! That looks astonishing! I think I may have to try that on mine.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 01-03-2021, 07:04 PM   #845
chewychevy67
Ok so before I start headlight surgery I did a comparison of what I have here. I compared a morimoto 3.0 I put in my van and the bulb that comes with the octane lighting kit I bought. Both are in the same octane lighting housings I have. The morimoto has an excellent pattern in my van And here it shows the same. The bulb on the left with a flatter pattern is the morimoto. The right is the octane bulb with no pattern at all. Just scattered light. I'll take another in my alley tonight when it gets dark. The morimoto weren't cheap but they are super nice to drive with in my van.
Old 01-03-2021, 08:57 PM   #846
TA_C10
TA_C10's Avatar
That is a big difference. Getting this combination right makes all the difference.
"It's only money".
Old 01-03-2021, 11:34 PM   #847
chewychevy67
This is a the closest to the top of the light I could get these on the right side so I did the left side to match. I wanted these done as gm did it on the cars so both need to be on the dim beam. These are on an extra headlight bezel I am just testing on
Old 01-05-2021, 03:48 PM   #848
chewychevy67
Passenger side wet arm wiper is finished. Turned out very nicely. Driver side will be more challenging
Old 01-05-2021, 04:03 PM   #849
TA_C10
TA_C10's Avatar
Did I miss an earlier post of you discussing this mod? I can't find it if so. You didn't say, but it appears you relocated your washer nozzles under the wiper arms and ran a rubber line up the arm to a remote wiper nozzle? Is this correct? Got a pic of the rubber in the arm and the new nozzle location up the arm and how it clips on?
Very cool. Nice work. If I am correct in my assumptions
"It's only money".
Old 01-05-2021, 04:16 PM   #850
chewychevy67
Yes I posted on it quite some time ago. Wasn't quite sure how I was going to do this without it looking unfactory. Here Is the hose up the arm.
