#2401 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 1972 Chevy 4wd Longhorn Project: Never Ending Changes
I've been using this truck hauling a lot of stuff and driving it everywhere. I had my first issue at the end of June hauling my camper. My bottom turbo is pushing/leaking oil and my air filter got really dirty. I removed the top turbo to put a different turbo on but I will have to redo my piping so I cleaned everything back up and put it back together so I can continue to use the truck. I just can't haul my camper long distances with it until I rebuild the bottom turbo. (I probably won't tow the camper at all just in case)
I finally got tired of my in bed 16 gallon fuel tank and got the 19 gallon Boyd welding tank installed. I couldn't make the marker light hole work as the filler door because my fill tube is so large. I ended up putting it inside the bed and made a box around it which allowed me to put my trailer wiring socket in a better place too. I still need to finish affixing the box to the bed side but it works for now. I also fixed the rust on the left rear corner of my bed floor. It was rusted through like most do where the bed side attaches. I cut out the rot on the cross member and installed new metal, then put the bed floor patch in. I despise the bed floor patch I got as it doesn't match the bends worth a darn. I'm on the search for a good steel floor for the next Longhorn build. I then welded the LH bed side to the floor. Soon I need to do the RH side. Someday I'll get the bed done......
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#2402 |
Next thing on the list is to get rid of the wood console I made to house my little larry valve, and ditch the little larry valve. That SOB will get stuck and continue to add air when it is in the middle position. Not cool. I'm going to put a regular leveling valve on it with a dump valve and be done with it. Then I need to finish hooking up my gauges, and I might put on borg warner turbos and my oil filter relocation stuff later on. Like the title says, never ending changes.
![]() My daughter rode with me to and from the car show in Oskaloosa last weekend. She passed out 10 minutes into the trip on the way home. The kids love this truck. I'm betting I'll be building them their own trucks on down the road. I did find another project last weekend but I don't think I'll pursue it. I just don't need another project. (Is that a thing?)
#2403 |
Nice to see it out and working . My little guy falls a sleep in all our stuff all the time . One time he fell asleep in the back of my old ford tractor. Full metal cab. Screaming away with the snow blower going . How do they do it ??? Lol...
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#2404 |
fillerneck looks nice . about the ribs in the floor : cant you get a metal shop to bend up a plate for you that matches the original ?
might be cheaper then cutting up an existing bed (you did say they all rust at that spot) or buy some extra tools and make youre own : ![]()
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#2405 |
![]() Join Date: Feb 2008
Looking good!!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#2406 |
Junk Yartist
I used Boyd Welding for the fittings in the cooling system. I am very happy with them so far.
Same deal with patch panels here... I hate the fitment. I am interested to see what you do for the suspension valve. For some reason I thought you used a standard leveling valve originally.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#2407 | ||
Thanks! Quote:
#2408 |
At least you can still drive it with the one turbo. Gas tank looks nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#2409 |
Still Learning
Very cool seeing you put your truck to work! Looks great towing the camper
#2410 |
I haven't really changed much on it. I did get the rear fuel tank installed and out of the bed. But I've just been using it and working it all the time.
#2411 |
That's OK these things happen. At least you are still driving it and loving it.
| Bookmarks |
