Old 12-13-2020, 12:21 AM   #1
tim_mc
tim_mc's Avatar
Re: 283ci Bracket Question
I used Summit SUM-G4050 ($7.99) and SUM-G4051 ($8.99) brackets, which mounts the alternator on the LH/driver side. They are offered in both chrome and black, and mount to the #1 cylinder header bolts, not the head.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 12-13-2020, 12:47 AM   #2
the67Beast
Active Member
the67Beast's Avatar
Thanks a lot. Those will be perfect.
I would keep the original rams horns, but they are rusted thru so I'll have to use what's available at the moment.
the67Beast is offline   Reply With Quote
Old 12-13-2020, 04:35 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 283ci Bracket Question
Well by the time you change the exhaust piping to work with the headers and pay the exhaust shop + buying the new brackets, you can replace the ram horns with some used ones and be back up running at the house without a trip to the exhaust shop.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-13-2020, 06:35 AM   #4
the67Beast
Active Member
the67Beast's Avatar
Good point Andy. I did not think about that.
Old 12-13-2020, 08:01 PM   #5
BigBird05
Some of us old hot roders just like headers.
BigBird05 is offline   Reply With Quote
