Roto Reuter thats the name...
![]() Join Date: Feb 2010
Need Help with Oil Pan Gasket Leak
So I finished my 5.3L LM7 4L60E swap on my 70 K10 in the early summer. I drove the truck over the summer, but over time I was getting more and more dripping from around my oil pan. I rechecked the torque on the pan bolts and tried to snug it up a bit, but I think I may have made it worse.
My oil pan is one fabricated by Tilden Motorsports and should be a good pan. I tried to remove the pan, but even after jacking up the front of the engine I can't get it out. In order to get the gasket out I had to finagle removal of the pick-up tube with the pan dropped, but still in place. It looks like I'll have to replace the gasket with the pan resting on the cross member. Looking at the pan, it appears that it may not be perfectly flat, but I can't tell for sure. I can't get any type of straight edge in there to check. I'm pretty much stuck using it, because I can't get it out. My question is are there any options for sealing it up better then the stock gasket. From what little I know, the stock aluminum o-ring style gaskets are supposed to be pretty good. In my case I had significant leaking mainly at the rear by the bellhousing. I also had leaking though at the front. Too much just to let it go. Any help is greatly appreciated.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Moderator
![]() Join Date: Jun 2017
Re: Need Help with Oil Pan Gasket Leak
I have had "many" issues with fabricated metal pans leaking on these engines...to the point now where I wont use one....
Cast aluminum pan is the way to go....replacing the gasket on a pan that is not perfectly flat will only leak again... One note...did you check the PCV system is working correctly and not allowing the engine sump to pressurize? Hope this helps ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2025 Chevy Equinox ![]() ![]()
#3 | |
How do you check this?
I know the stock gaskets are meant to be installed dry. Any issues with using a small amount of Permatex 82180 (Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker) along with it?
You don't want any silicone on the gasket except where it's supposed to be, the 4 corners where the front and rear covers seams are. There's a place on the gasket for it, it has hash marks on it. Did you seal it there? Unfortunately, if you cant get the pan off, you probably wont be able to get the gasket around the pick up tube either, so if you didn't seal the corners, you should be able to do that by just dropping the pan as much as you can.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#6 | |
BMW & ASE Master Certified
Just take the motor mount bolts loose and rise the motor up a few inches to give the clearance needed to slide the pan out, then sell it and get a aluminum one..
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Thanks, but I already tried that. Jacked the motor up until the PS head hit the firewall. As far as I could go. There is still not enough clearance to remove the pan. It's too bad that the Tilden 4WD front cross member wasn't removable or able to be dropped.
So here's what I ended up doing today. I loosened the motor mounts and jacked up the engine until the passenger side head hit the firewall. It still did not provide enough clearance to remove the oil pan. So I decided to disconnect the oil pick up tube, so I could get a new gasket in around it. What a PITA.
I cleaned up both surfaces really well and made sure they were good and dry. Bought a new gasket and pick up tube o-ring. I slid the gasket into place and spent over an hour trying to get the pick up tube pack on. There just isn't enough room this way to do it (easily). I was able to get the pick up tube back into place, but I had to use the existing o-ring, because the new one was fatter and would not go on. The existing one looked in good shape. Hopefully it is. I put a very, very light film of Permatex black RTV on the oil pan surface to hold the gasket in place. I then sealed the 4-corners as required. Got the pan back up and torqued all bolts to 18 ft-lb, except back wall two, which I torqued to 106 in-lb. I'll keep my fingers crossed and hope that it seals it. Being in Buffalo, I won't find out now until spring. Oil pan dropped, but hits Tilden 4WD cross member. Motor mounts loosened and front of engine jacked up as high as it could go. Still not enough room to remove the oil pan. Oil pick up tube dropped down so new gasket could be installed. Oil pick up tube back into place.
Moderator
If memory serves me right....
You can undo the mounting bolts that hold the Tilden crossmember into the chassis rails and slide it forward enough to give you better access.... Just mark the chassis so you can re align the crossmember after the move.
#11 | |
When I installed my crossmember I recall it fitting very tightly. It would need persuading to slide it forward, but I suppose it could be managed. Probably easier then removing the engine. Thanks for the input.
| Bookmarks |
