Old 07-02-2016, 03:29 PM   #1
Afirehawk1
66 c10 standard vs. custom steering wheel
Having trouble finding a pix to compare the 2.
I have a steering wheel but not sure which
Afirehawk1 is offline   Reply With Quote
Old 07-02-2016, 04:02 PM   #2
jtrichard
Re: 66 c10 standard vs. custom steering wheel
IF the horn button is round then it is standard wheel
Here is a custom http://67-72chevytrucks.com/vboard/s...d.php?t=680473
and http://67-72chevytrucks.com/vboard/s...d.php?t=539657
Post #2 here is a standard wheel http://67-72chevytrucks.com/vboard/s...d.php?t=210674
jtrichard is offline   Reply With Quote
Old 07-02-2016, 04:28 PM   #3
Afirehawk1
Only have the wheel. No horn ring.
Is the ring the only difference?
Old 07-02-2016, 05:36 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Custom/Deluxe Steering Wheel info: http://www.oldchevytrucks.com/blog/i...eering-wheels/
Old 07-02-2016, 09:27 PM   #5
Afirehawk1
So are the wheels the same then?
Old 07-02-2016, 09:38 PM   #6
Chknlyps2
No, by looking at the link in post 4 the 60 to 65 deluxe wheel has the spokes at 3 and 9 o'clock, the 66 deluxe in that link has them more like a standard wheel where the spokes are at around 4 and 8 o'clock. Kinda looks like the standard wheel has the spokes angled down just a tad more though, hard to tell from the pic
Chknlyps2 is offline   Reply With Quote
Old 07-02-2016, 11:08 PM   #7
cru_zn_29
cru_zn_29's Avatar
Wheel is the same.
cru_zn_29 is offline   Reply With Quote
Old 07-02-2016, 11:14 PM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Originally Posted by cru_zn_29 View Post
Wheel is the same.
60- 65 had a standard wheel, and a separate different deluxe wheel.
66 used a "new wheel" (just happens that it is also the same as a 65 nova wheel) this wheel is completely different than the previous 2 wheels, standard had a horn button, and deluxe had a horn ring.
pic of deluxe 66 only wheel:
Old 07-03-2016, 09:48 AM   #9
MisterC
MisterC's Avatar
I was needing that same information as well. Forum member, 60-66, gives detailed answer at the end of this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=611310
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 07-03-2016, 11:09 AM   #10
cru_zn_29
cru_zn_29's Avatar
The 66 wheels are the same the 66 deluxe horn cap and horn ring makes it a deluxe.
Old 07-03-2016, 11:31 AM   #11
Afirehawk1
Great info gang! Thank you
Old 07-03-2016, 11:44 AM   #12
60-66
60-66's Avatar
There are three 1966 steering wheels. Top left 1966 Deluxe wheel, Top right 1966 same wheel as deluxe but a small horn button . The bottom standard steering wheel that was used in all years with variations in color , per year.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-03-2016, 12:11 PM   #13
Afirehawk1
So the steering wheel itself is a little different, thanks
Old 07-03-2016, 01:10 PM   #14
60-66
60-66's Avatar
No , I see where I may have mis lead you and fixed my mistake. The top two wheels are identical , only difference is you swap out horn rings and parts. Bottom wheel was used 1960-1966 but there were three different colors. Dark Grey 60-61,white 62-64 and fawn on some 1964s and fawn 65 66.
Old 07-03-2016, 01:17 PM   #15
oem4me
An early wheel on a 66? that's news to me, Jon. Not saying you're wrong (as you never are), just that I've not seen one before. Another plant-specific item maybe? Perhaps I just never noticed.
Old 07-03-2016, 01:37 PM   #16
60-66
60-66's Avatar
What I've noticed, Bruce is 1966 3/4 ton trucks seem to have the early wheel unless its a custom truck. Factorystock referred to the steering wheel as the "heavy duty" steering wheel in another thread. I have a couple 66 parts trucks here with that wheel , not sure why or what reasons for it other than what I've seen and they are C20s. Its also the ONLY wheel you could get in 1960-1966 GMC Custom or standard.
Old 07-03-2016, 01:57 PM   #17
60-66
60-66's Avatar
Also , just remembered my 66 K10 panel has the early steering wheel.
Old 07-03-2016, 06:01 PM   #18
oem4me
Got it. My ignorance illustrates how easily we can draw incorrect conclusions based on limited observation. ...So much to learn, so small my brain
Old 07-03-2016, 06:13 PM   #19
jocko
jocko's Avatar
So, Afirehawk1 - to ultimately answer your question (and it has pretty much been answered) - if you have #1 of 60-66's 3 wheels - you have a 66 Custom where. If #2 of 60-66's 3 wheels - you can add the big horn ring to #2 and make it a Custom. The wheel itself is identical. If you have #3, it is what it is. And to avoid any confusion - the first reply you received from jtrichard - the first pic is a 65 deluxe wheel, not a 66 (and it is one of my favorite wheels).
Old 07-03-2016, 06:33 PM   #20
Afirehawk1
Yep thanks
Old 12-15-2020, 11:43 PM   #21
dmjlambert
dmjlambert's Avatar
What is the outside diameter of the 1966-only C-10 steering wheel?
