Old 12-07-2020, 12:18 PM   #676
AU Doc
Re: 1971 Stepside LS Build
I know with aftermarket ECMs, remote tuning is pretty common.
AU Doc is offline   Reply With Quote
Old 12-07-2020, 12:49 PM   #677
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Mine is the GM ecm from the Denali donor.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-07-2020, 01:30 PM   #678
AU Doc
I would think a tuner could do the same for a factory ECM. I see people discussing remote tunes pretty regularly on some of the FB groups I'm in, and on some pretty wild combinations at that. But every tuner is different. And if you've found someone that's good at it, it may be worth taking it to them if that's how they prefer to operate.
Old 12-07-2020, 05:45 PM   #679
Custom 68
Custom 68's Avatar
I believe a tuner can e-mail you the file or even get into the ECM so yes it can be done remotely however I believe it requires the owner to have HPTuners or EFI Live (depending on what they are using.) That purchase can add up pretty quickly. I know he is looking local for the tune that makes it easier to get updates and not have your truck down.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-07-2020, 05:57 PM   #680
1971Stepside
Almost Satisfied
Dave
I've asked ShowMe Speed if they can get me on their dyno this week. As of Friday, they said they could. I asked for Thursday since it is supposed to be 70, but I have not heard back.
Old 12-08-2020, 12:08 AM   #681
Custom 68
Custom 68's Avatar
Good luck Shannon
Dave
Old 12-08-2020, 12:05 PM   #682
71cadc10
71cadc10's Avatar
what I like to do to try and get all the air out, is unhook the 'steam fitting' cross over at the front under intake. Put a towel under the metal line where you unhooked the rubber hose here....
you want to keep filling the radiator slowly until you start to push water out that metal cross over line. That way you know the block and heads are full and air is pushed out.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 12-11-2020, 08:53 PM   #683
Low Elco
Looks great, hope to see it in April!
Low Elco is offline   Reply With Quote
Old 12-14-2020, 10:00 AM   #684
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I hope this works out for you. I explored the notion of putting my K10 on the dyno with a local company. They also have several options for tuning, including HP Tuners, which was how mine was set up. I used Pacific Fabrication / Tilden Motorsports for mine. By the time he added up everything I was pushing $600 - $700. He also said that he needed to add an extra bung to my exhaust system for monitoring. I quickly said no to that. I have a nice SS exhaust system that I don't need hacked up. Also, my tune seems to be OK. It's just that I wanted to see about tweaking the shift points and looking at my fan temperature settings. Good luck with it.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 12-14-2020, 10:29 AM   #685
1971Stepside
Almost Satisfied
I have the dyno run scheduled for Friday if the weather cooperates. The shop I'm going to has a love them or hate them reputation. I've seen a little of both in the process, but I think they will get it pretty close. Once it is fully going and warm again I can tweak it. I've spent the weekend going over everything I can think of to make sure we have a good run Friday.
I also worked on a new set of kick panel speaker enclosures. I just didn't like the first set that I built. I laid the speaker flat this time so the enclosures would be much thinner overall. I made sure I had room for the dimmer switch and I angled the tweeters to hit about the middle of the back glass. I am really happy with how they fit and look. A little more sanding and I can drop them off to be covered.
Old 12-14-2020, 10:48 AM   #686
derotoreut
derotoreut's Avatar
Sweet. You can always move the dimmer switch a little if you need to. I decided to put mine in my Ididit steering column just for this reason. Looking great though. Nice work.
~ Dan
Old 12-14-2020, 04:08 PM   #687
1971Stepside
Almost Satisfied
Some old school fun here. Found this picture. I'm guessing around 1989 I was putting a new stereo and speakers in the truck. I since repaired the cut dash.
Old 12-14-2020, 04:11 PM   #688
1971Stepside
Almost Satisfied
While digging I found these two square bodies that were my dads. I would love to build a 79 GMC like that green one. It was my favorite truck he had.
Old 12-14-2020, 05:37 PM   #689
72 tigger
72 tigger's Avatar
Nice square bodies!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is online now   Reply With Quote
Old 12-14-2020, 08:51 PM   #690
Kronald_70GMC
Kronald_70GMC's Avatar
Those speaker enclosures are awesome man! Good work!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
Kronald_70GMC is offline   Reply With Quote
Old 12-15-2020, 10:37 AM   #691
MDPotter
MDPotter's Avatar
Yep, those speaker enclosures are top notch. My grandpa had an 84 K20 with the 6.2 diesel (about the slowest truck I've ever driven) and it was parked in the weeds for a couple years before a neighbor bought it for farm use and had it repainted and then sold it to another guy who swapped in a 350 and I think it's changed hands again. Should have kept it...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 12-15-2020, 02:19 PM   #692
88Stanger
88Stanger's Avatar
I am curious, what size of Mids are these? 6.5"? I am looking at doing the exact same thing and want to order the precut round wood speaker rings.
and then i need to find the tweeter ones. lol
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 12-15-2020, 03:30 PM   #693
1971Stepside
Almost Satisfied
They are 6.5" mids. Grab you a piece of 1/2" MDF at Lowes or Depot and cut your own rings. You just need a jig saw. I guess you might need a router too. Good luck.
Old 12-15-2020, 03:35 PM   #694
1971Stepside
Almost Satisfied
I sanded them last night. Won't take much filler at all to smooth them out.
Old 12-16-2020, 03:26 PM   #695
Putzer
looks great!! Are you going to paint or wrap them?
Putzer is offline   Reply With Quote
Old 12-16-2020, 04:06 PM   #696
1971Stepside
Almost Satisfied
Thanks! They will be wrapped with the red vinyl like the door panels, seat, etc.
Old 12-17-2020, 05:27 PM   #697
1971Stepside
Almost Satisfied
Dyno run cancelled for tomorrow....ugh. It is amazing how hard it is to spend your hard earned dollars sometimes.
Old 12-17-2020, 05:40 PM   #698
SkidmoreGarage
sorry to hear about that setback.
That's been my experience as well, especially with "tuners" and "high end shops who do racecars/restorations". Maybe it is just surprising how many people who get into the automotive aftermarket just don't act like professionals. Why is it "okay" for shops to cancel/turn down work/treat you like crap/do shoddy work when they want, but not okay in other areas of our lives? I wish there was something that could change, these guys (and gals) can't be having fun. Maybe it's all economics, but there is more money than ever in cars... Sorry to hijack.
SkidmoreGarage is offline   Reply With Quote
Old 12-18-2020, 10:36 AM   #699
Custom 68
Custom 68's Avatar
Ugh Shannon I was wondering if you were gonna be a go today. I got mine out on this nice cool morning. You will get there!
Dave
Dave
Old 12-18-2020, 11:57 AM   #700
1971Stepside
Almost Satisfied
Dave
I'm looking for another place out of town. I may take it to KC to have it tuned. Hate to go that far, but we just don't have any good options here. I really don't need it to be perfect right now, I would just like it to run clean enough to circle the block a time or two so I can verify everything is working.
