Tie down location
Hi All,
i have a 1969 K10 Suburban with Barn Doors.. i want use it to transport my bike (1958 BMW R26) to a location 150 miles away.. (The height fits). Also i am to order a camping box so that i can have a mobile kitchen( will share pics once i will have it) normally this is hold in place using tie down straps using factory hooks for othet vehicles.. Also i would need to secure my bike while at transport.. What solutions did you use to attach tiedown straps or did you install some hooks somewhere I’m not sure whether the 60 year old plywood will hold and didn’t want to just drill to metal frame or wooden floor.: Anybody done anything before that I can just copy? Thank you Sinan
Istanbul - Turkey 1969 Chevy 4x4 Suburban - i6 250 ci 1953 Willys CJ-3B - 1969 Opel GT 1996 Lotus Elan s2 - 1993 Lotus Esprit s4 1995 Maserati Ghibli - 2000 Porsche Carrera 4 1958 BMW R26 |
![]() Join Date: Feb 2016
Re: Tie down location
The wood isn't likely to hold the tie downs alone but there are metal stiffeners (A quick look underneath will show what I'm talking about) under the wood and if you drilled through those and bolt tie down hooks or loops to those with a nice thick fender washer on top, I believe you would be okay.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
one time trip or are you planning to do this again? the answer to that question would affect my advice..
for a one time trip, I wouldn't modify anything, I would fabricate something to block the bike down to and slide it in there.. maybe collapsible or adjustable cargo brace or two and be done.. if this is something you're planning to do often in the future, I would recommend a high quality track system, mounted through the floor into the steel cross members for strength and adjustability.. for fully adjustable and versatile cargo restraint, tracks may fit on the sides as well.. use rivnuts (riveted style well nuts) good luck! temporary Cargo Bar Adjustable 40"-70", Small Rapid Ratchet Strong Steel Load Lock Rod for Pickups, Vans, & SUVs ![]() permanent Pit Posse 4' Aluminum S Track Tie Down Rails Set Of 2 – Heavy Aircraft Quality Aluminum - Adjustable - For Flatbed, Truck, Cargo, Van, Enclosed Trailer - Automotive Accessories– 5 Year Warranty Silver ![]() for mounting in sheet metal blind areas like inner side panels under the windows ![]()
I started out with nothing - and I still have most of it |
Thanks for the advice, i will try to find something similar like in the picture, though it is difficult in Turkey .. ( fabricating might be easier)
After HO454 ‘s response i thought i will just get some hooks, use the existing cage nuts for the third row seat and bolt two hooks down to use a temporary strap location.. they are not as wide as they ideally should be but maybe they will be okay.. This would solve my bike transport issue... But i am also thinking about putting a big camper box, like a massive aluminium driver, to use as a mobile kitchen, fridge and storage.. for this i would need a more permanent bolt down location.. do you think i can just idrill some rivet nuts to the metal side floor panels that hold the plywood down. Or to the sides? ( metal sheet behind the interior side panels?
Istanbul - Turkey 1969 Chevy 4x4 Suburban - i6 250 ci 1953 Willys CJ-3B - 1969 Opel GT 1996 Lotus Elan s2 - 1993 Lotus Esprit s4 1995 Maserati Ghibli - 2000 Porsche Carrera 4 1958 BMW R26 Last edited by sinannasirli; 12-17-2020 at 06:23 PM. |
Some locations... which one would you drill? ![]()
#6 | |
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
