Question about clutch break in
The clutch went out on my 1968 C10, 327 w/ 3 speed transmission. Had a local shop put a new clutch kit in.
Curious to know if there is a clutch break in period or procedure? I can't recall doing anything before to break a clutch in before. Last clutch was brand new in March 2017 when I had my 327 rebuilt and reinstalled. I went easy on the motor as part of the break in. Old clutch was a HD Borg & Beck style and one of the fingers cracked causing issues with the clutch not wanting to release properly. |
Re: Question about clutch break in
I'm no expert, I'm only speaking from a lifetime total of 4 clutch jobs.
However in my experience there is no "break-in" procedure. Although, you absolutely should fine tune its adjustment if necessary. |
All about them K’s
![]() Join Date: Jun 2014
Make sure it’s adjusted properly if your still on the mechanical linkage, other than that just drive it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
