Old 07-06-2004, 11:27 PM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
What to do with the frame.
I just aquired a 1972 C-10 that is in need of a lot of work. I was going to remove the bed, front end and motor and tranny so I can fit them in my garage due to lack of space and strip the paint and do the body work. What sort of things should I do to the frame, brakes, suspension while I have most of the body off. The cab will come off when the rest of this is done but I really have no clue as to were to start or what needs done. As far as I know,the brakes work but it has been sitting for 7 years. Thanks.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 07-07-2004, 01:43 PM   #2
cdowns
cdowns's Avatar
start at the front and work your way back , everything should be checked cleaned painted repaired/replaced if needed
