Old 12-09-2020, 02:04 PM   #576
roll_the_dice
roll_the_dice's Avatar
Re: 1965 LWB Stepside Build
Originally Posted by 88Stanger View Post
I want a set of those, so if you decide not to use them, i may be interested in buying them from you.
By the way AWESOME build! great work sir!!
Thanks dude! I appreciate it! I will give you the right of first refusal if I decide to sell them.
Originally Posted by straight6chevyguy View Post
I think the sale panels look good.
(I have the same ones on my 65 by the way!)
Thanks! I actually like the 60-63 panels better than the correct 64-66. I really like the bow tie...ever have anyone say, they are the wrong panels on your truck? I assume 99% of anyone won't know.
roll_the_dice is offline   Reply With Quote
Old 12-09-2020, 04:06 PM   #577
straight6chevyguy
straight6chevyguy's Avatar
No, but it's been a farm truck since we have had it so not to many people have seen it. (not anyone that knows that there the wrong ones anyway lol)
I actually did not know that they were not correct until just a few years ago!
BTW I also think the 60-63 panels look better than the 64-66 panels.
I too really like the bowtie.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 12-09-2020, 04:37 PM   #578
roll_the_dice
That's what I figured!
Old 12-09-2020, 04:41 PM   #579
roll_the_dice
Installed my rubber floor mat. It really finishes the interior from seeing the insulation on the floor. I still need to install the shift boot...should be here tomorrow. I also need to fit the pedal a little better around the ball studs. Overall it is a good fit and I like the look.
Question...for those that have installed...look at the last picture....did you cut the mat around the door sill or put it under the sill? I am inclined to put it under, but it is a fairly thick mat not sure how it will fit.
Old 12-09-2020, 04:52 PM   #580
WunTon
Looks awesome! I would go under the sill if possible to help hold it in place while getting in and out so you don't catch a shoe on it and to keep from collecting crap in/under it.
WunTon is offline   Reply With Quote
Old 12-09-2020, 11:18 PM   #581
cwcarpenter98
cwcarpenter98's Avatar
Lookin' good! I believe the rubber mat goes under the sill plates. At least, that's how my truck is, and I think it looks better that way
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-10-2020, 11:47 AM   #582
88Stanger
88Stanger's Avatar
great work!
88Stanger is offline   Reply With Quote
Old 12-12-2020, 10:16 PM   #583
Johns 66
Johns 66's Avatar
Looks Awesome And
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 12-12-2020, 10:21 PM   #584
roll_the_dice
great work!
Originally Posted by Johns 66 View Post
Looks Awesome And
Thanks Guys! I appreciate it.
Anyone have any ideas? I can't get my gas gauge to work. I bought a new repop gauge and have tried the 50+ yr old gauge. New sending unit in my gas tank 0-30 OHM. THe new one reads at empty and the old one pegged at full...now it shows about an 1/8th of a tank. I honestly don't know how much gas I have in the tank and with the bed on...the rear tank is difficult to work on....suggestions?
Old 12-19-2020, 11:08 AM   #585
roll_the_dice
Finally got my parking lights wired yesterday (bad picture)...and I also made up a wiring harness for my trans backup light switch to my AAW harness. I really like these weatherpack connectors I bought. Now that I am finished (primarily) with wiring the truck, I have determined I enjoyed the wiring process. It really lets you know how everything works and is connected for the truck.
Old 12-19-2020, 09:57 PM   #586
Johns 66
Johns 66's Avatar
Glad you are getting all the little things took care of....Im sure a few gremlins will pop up every now and then...but at least you know everything about ole girl to be able to fix it
2019 GMC AT4
Old 12-20-2020, 07:39 AM   #587
The Rocknrod
Moderator
The Rocknrod's Avatar
That floor rubber looks good.
Old 12-20-2020, 10:46 AM   #588
88Stanger
88Stanger's Avatar
Roll_The_Dice - Are you still using the Fi-Tech setup? I have one a bought a few years ago that was for my "69, but some changes happened and ..... well now i have a very slightly used Fi-Tech 600HP Blow Thru i am going to try and was just wondering what you have been experiencing ..
John 3:16 - Saved me... God Bless
Old 12-20-2020, 11:11 AM   #589
roll_the_dice
I have it...I like it for the most part. I don't think it is running 100% correctly. I have been talking to FiTech to get it straightened out. Their customer service has been pretty good so far. I can't get the IAC to stay set even though it runs good once warm...cold start isn't great which to me is the whole point of EFI. I plan on talking to them again this week. I am sure once dialed in correctly it will be great...just not there yet. I would definitely do it again though.
Old 12-21-2020, 03:28 PM   #590
roll_the_dice
Got some pretty stuff installed...door panels, horn ring, and rubber matt. I still need to paint the doors and repair some small rust at the bottom (spring project).
Weird thing...I installed the horn ring yesterday and this morning my battery was dead...I charged it back up...and removed the horn ring. I will see if that solves the battery drain. Must be making slight contact or something...if it drains again in the morning without the horn ring, I will investigate further.
The picture of the SW/Horn ring was shot through the back glass...I like the reflection of the bed sides and wood in the glass.
Old 12-21-2020, 04:59 PM   #591
roll_the_dice
Also got in my gear shift boot and ring...and couldn't wait to install it. I LOVE IT!
Old 12-21-2020, 05:00 PM   #592
WunTon
Man everything looks great but I really love your shifter!
Old 12-21-2020, 05:42 PM   #593
Johns 66
Johns 66's Avatar
Looks killer Andy.....I like the green on the door inserts.....
Fingers crossed that the FiTech folks can get you fixed up
2019 GMC AT4
Old 12-21-2020, 07:17 PM   #594
roll_the_dice
Thanks! Much appreciated! I really love the shifter too. I love the Indian motorcycle shift knob I picked up years ago. The shift boot is out of a 67 C10 and the ring was made from a fellow board member out of billet aluminum and is anodized. I think they look great and belong on the truck perfectly!
Thanks John...I love the doors as well. I think the green sets it off well. I think Fitech will get me figured out.
I went and filled up the gas tank tonight..and took it for a spin and stopped by a friends house. The truck is running good...just need to get a few things dialed in. Got to put in a new sending unit, mine apparently died over the last 3 years, but Boyds welding is sending me a new sending unit for the gas tank. So that is good customer service! Got a whopping 22 miles on it now! WOOHOO!
Old 12-21-2020, 10:07 PM   #595
cwcarpenter98
Lookin' great!
Do you have the horn hooked up to the horn relay? If not, see if you can hear the horn relay click when you install the horn ring. If you don't get the metal washer spring thingy in the right place, the horn will stay grounded all the time
Christian Carpenter
Old 12-22-2020, 01:23 PM   #596
roll_the_dice
Lookin' great!
Thanks Christian! I figured out the battery drain..I had my reverse lockout switch on my trans wired to a battery terminal in the harness instead of ignition...oops. Corrected...charging battery again as we speak. Also hooked the horn button back up.
Old 12-22-2020, 01:56 PM   #597
The Rocknrod
Moderator
Like the interior a lot. Nice work
Old 12-22-2020, 02:37 PM   #598
roll_the_dice
Thanks Master Chief, I appreciate it! I have one more piece to add to the interior...an OEM dash clock. Hope to get it installed in the next week or 2.
Old 12-27-2020, 07:11 PM   #599
roll_the_dice
Got my seat belts installed this weekend. Have put 77 miles on it since Thanksgiving...more than half of those in the last week. Took it out yesterday for testing purposes of the brakes. I adjusted the push rod some...might need a little more but much better.
Took it out today for actual enjoyment...went to some antique stores and putzed around...was nice and fun. Beautiful weather for a drive...mid 50's.
Old 12-28-2020, 05:51 PM   #600
roll_the_dice
For my timeline and reference...I installed a new upper radiator hose today. Gates # 23464
I also installed a LectricLimited temp sending unit.
