Old 10-18-2020, 07:26 AM   #51
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1956 3100 build
That thing is looking nice. Thanks for the update.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-19-2020, 10:39 PM   #52
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks dale. these mods are on my to do list need i need to do smooth firewall soon so i can send cab back to my bodyman to finish.:
56 3100 is offline   Reply With Quote
Old 12-17-2020, 11:13 AM   #53
56 3100
56 3100's Avatar
Re: 1956 3100 build
i want to say thanks and give credit to everyone i messaged and any i borrowed ideas from. here is pics of my firewall in progress.template first
some magnets to hold in place.
lots of small welds time consuming but no warpage! used wet rag to cool welds not shown.
seat mounts for 3rd row tahoe seats using speedway motors flat tracks.
do seats look better with headrest or without?
Old 12-20-2020, 09:20 AM   #54
Ol Blue K20
Re: 1956 3100 build
I think they look better without them .
Dale
Old 12-20-2020, 02:25 PM   #55
G&R's57GMC
G&R's57GMC's Avatar
Re: 1956 3100 build
But your head will feel better with them
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 12-20-2020, 07:36 PM   #56
56 3100
56 3100's Avatar
Re: 1956 3100 build
headrest come off easy so will trial it when up and running. here is my attempt at steering column cover and dash extension. credits to Ogre on this
forum for the details on his build page. winging it from there.
Old 12-21-2020, 12:12 PM   #57
Rickysnickers
Re: 1956 3100 build
Question regarding the firewall panels. This may sound like a dumb question, but here it goes. How do you attach the top edge of the panel to the actual firewall? Is it welded, panel bond, or? If it's welded how do you carefully grind down the welds?
Old 12-21-2020, 01:05 PM   #58
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hi Ricky i welded the panels on. small welds cool with with wet rag and repeat. no visable distortion. i used edge of mini grinder wheel for around edges. it was time consuming. will post pic shortly
Old 12-21-2020, 07:30 PM   #59
56 3100
56 3100's Avatar
Re: 1956 3100 build
[QUOTE=56 3100;8852741]Hi Ricky i welded the panels on. small welds cool with with wet rag and repeat. no visable distortion. i used edge of mini grinder wheel for around edges. it was time consuming.
Old 12-22-2020, 11:12 AM   #60
Rickysnickers
Re: 1956 3100 build
Wow, thank you. Very nice job!!!
Old 12-22-2020, 08:27 PM   #61
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks Ricky. i talked to JML55 on this forum and he gave some pointers. i welded some holes from under dash. i found this link here as well that really helped.
https://www.hotrod.com/articles/1204...ng-a-firewall/
next job has been i flattened a piece of copper tube and used foil tape to stick it to under cab on floor to weld up all holes previous seats mounting holes . filled in all other holes not needed in floor as well.
8751-6-DBC099708-C1.jpg[/img]
Old 12-24-2020, 01:00 AM   #62
dsraven
Re: 1956 3100 build
that's improvising, sweet.
I have a C clamp that I cut the bottom leg off (so now it looks like a 1/2 c clamp) and screwed a magnet to that part. it sticks well to flat surfaces like a floor or firewall. then the adjustment part I use to screw down a copper plate over the hole I am trying to patch up. that way I can tack in a patch and then get rid of the magnet so the distortion and interference to the weld is gone for a nicer finished weld. it does stutter and spit because of the magnet but if you work alone and can't be under the truck and still weld on the inside.....at least the patch gets tacked in before the magnet goes away. I have thought about a C clamp with more offset. maybe build one if I get a minute.
Old 12-24-2020, 10:50 AM   #63
56 3100
56 3100's Avatar
Re: 1956 3100 build
hi raven is it just me or does trying to mig weld around magnets make for weird reaction? lots of spitting and sputtering like as if gas isnt turned on?
Old 12-24-2020, 11:08 AM   #64
dsraven
Re: 1956 3100 build
Yup, magnets distort the weld somehow. Not sure on the theory of it all. I usually just use them to tack and once the pieces are stuck together
Old 12-24-2020, 11:22 AM   #65
dsraven
Re: 1956 3100 build
Once the parts are stuck I remove the magnets and tack a few other spots, then grind off the crappy tacks.
Old 12-24-2020, 11:45 AM   #66
56 3100
56 3100's Avatar
Re: 1956 3100 build
its when tacking i notice it
Old 12-24-2020, 12:38 PM   #67
Tempest67
Tempest67's Avatar
Re: 1956 3100 build
I have noticed that before when tacking, so I Googled it.
Here you go
Do magnets affect welding?
When using magnets to hold parts for tack-welding, keep the magnets away (at least 6'' )from the spot you're welding. Magnets make a strong field that disrupts the arc. Welding close to a magnet can be very difficult or impossible.
Tempest67 is offline   Reply With Quote
Old 12-24-2020, 12:48 PM   #68
56 3100
56 3100's Avatar
Re: 1956 3100 build
Thanks Temptest. as they say google is your friend.
Old 12-24-2020, 02:26 PM   #69
slammed57
slammed57's Avatar
Re: 1956 3100 build
comin along nicely!
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 12-24-2020, 11:58 PM   #70
56 3100
56 3100's Avatar
Re: 1956 3100 build
Thanks slammed looked over your build pretty wicked.
Old 02-14-2021, 10:06 PM   #71
56 3100
56 3100's Avatar
Re: 1956 3100 build
back at it!got inner fenders trimmed around camaro a arms. and front sheet metal test fit.
Old 02-15-2021, 11:44 AM   #72
62 Barnfind
62 Barnfind's Avatar
Re: 1956 3100 build
Question about your lower dash. How wide is it?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 02-15-2021, 03:21 PM   #73
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hey 62barnfind lower dash is 4" props to Ogre for pics i followed his for my diy.
Old 02-15-2021, 11:43 PM   #74
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 1956 3100 build
Coming in late on this thread but I'm impressed with everything you've done.
You're planning to make the dash extension using fiberglass? It looks like flat thin plywood strips and the bottom curve is a cut shipping tube. Is that about right? How did you bend the plywood to follow the curves of the dash at the ends? I wonder if table saw cuts half way through would be enough or not? Also wonder how the cut shipping tube will follow that bend?
EDIT: Just went back to post #56 and I see a separate piece of plywood curve at the ends. BUT... is the long straight piece held on in some way? I'm thinking a 1x1 or a piece of small angle iron screwed to the underside of the dash?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-16-2021, 10:22 PM   #75
56 3100
56 3100's Avatar
Re: 1956 3100 build
Hi Dan thanks for the encouragement.its goes without saying this site is a great source of ideas. onto the dash extension. it is 1/4" plywood for main length. the ends are glued on with PL premium. and a couple small nails. a couple hidden screws holding sides to body. mailing tube is used for curved on bottom. i just shaped regular cardboard for end corners. it is going to be mounted to bottom of dash with some old pieces of shelving channel.i went with 73-87 chev truck emergency brake pedal. as i would not have been able to put extension on drivers side with underdash pull handle .
