Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-24-2019, 10:02 PM   #226
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
SEM seam sealer looks good! Not sure if I put on too much. Decided to let it run into the seam and find it's own level instead of running my finger along it.
Sorry my computer just does not want to upload things right side up!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 03-14-2019, 11:27 AM   #227
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
I re worked the driver side wheel lip area and I’m pretty happy with the results. And once again the pictures are rotated.
Old 04-09-2019, 12:33 PM   #228
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: NJ Suburban
Paul
If you are taking pics with an iphone Rotate them on your computer and then save them as something else in a different file. From what i have read, even if you rotate and save back as the original file it will still default to the original picture
Burb is coming along nicely
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is online now   Reply With Quote
Old 04-09-2019, 09:19 PM   #229
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Originally Posted by richard2717 View Post
Paul
Richard
I'll try that Richard. I think these were taken with a camera though. I've spent the last three weeks block sanding.
Old 12-16-2019, 05:41 PM   #230
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
It's been a while since I've posted. For the past 4 months I've been working on the drivers side panel between the drivers door and the wheelwell. It has been really kicking my butt. Yesterday I decided to sand off 4 months of body work and start over. I've got to make the metal straighter first.
Paul
Old 12-16-2019, 07:02 PM   #231
richard2717
Re: NJ Suburban
Man that sucks, Paul. I am just starting in on the heavy stuff on my panel and will have to do same repairs as this. I hope the new patches are better than what you described.
Members I have met.
Old 12-16-2019, 08:41 PM   #232
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Richard other guys have said the lower patch panel fit fine for them. Hopefully yours will fit correctly. It's weird. As I was applying the filler it looked like I just needed a skim coat. My long ruler showed the panel to be basically flat. It seemed like I was continuously adding more and more filler. When I sanded it all off that's exactly what was there. It looked like rings of a tree. It took hours to remove it all. Now again at bare metal and my long ruler shows it to be basically straight!
Paul
Old 05-16-2020, 12:48 AM   #233
HO455
HO455's Avatar
Re: NJ Suburban
Thought I would poke the big cat and see what happens. The last post was a while ago.
RIP Bob Parks.
Old 05-16-2020, 03:29 PM   #234
Average Joe
Average Joe's Avatar
Re: NJ Suburban
Poke poke! Lol
Perhaps small engine repair is busy with spring time and all...
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 05-18-2020, 10:13 PM   #235
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
The Suburban is coming along slowly. Body work wasn't going well. This time last year I figured I'd have body back on the frame. After working on the drivers side for 7 months late last year I sanded the body down to metal again and rewelded the patch panel for the loooooong drivers side panel. Hundreds of dollars worth of filler and paint went into the shop vac. Things are much better now and hopefully I can make more progress this spring. I'm hoping to be able to wet sand the roof and apply a base/clear white while it is on the rotisserie.
I retired from teaching 2 years ago and I'm busier than ever with a full time maintenance job and working around the house.
No pictures worth sharing. They all look the same. A huge tub on a rotisserie with lots of grey primer on it.
Thanks for the poke guys!
Paul
Old 08-19-2020, 09:18 PM   #236
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Wow last update was May! Holy crap!
The body work is probably 90% done and I'll finish it off when the body gets put back on the frame. Roof is ready for paint and that will happen after the body gets rolled outside and both the body and garage get a deep cleaning. Now all I have to do is settle on a paint brand!
Paul
Old 08-20-2020, 12:27 AM   #237
LockDoc
The Older Generation
LockDoc's Avatar
Re: NJ Suburban
Paint will make it all worth while. It looks good.
LockDoc
Leon
Old 08-20-2020, 09:21 AM   #238
richard2717
Re: NJ Suburban
Looking good Paul
Members I have met.
Old 08-21-2020, 07:07 AM   #239
zicc1835
zicc1835's Avatar
Re: NJ Suburban
wow ..... like to take a ride up see it in person
zicc1835 is offline   Reply With Quote
Old 08-22-2020, 05:20 AM   #240
Average Joe
Re: NJ Suburban
Looking good Paul
I second that.
Gonna be a beaut!!
Old 09-28-2020, 08:15 PM   #241
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Finally some progress. Painted the firewall/cowl and the roof this past week. Next step is to put the frame back under the body. I was planning on leaving the rotisserie attached to the back and support the front with a wide board like a 2x12 under the roof at the front doors. I'd make piers on either side with concrete block or 6x6 so my heavy duty screw type jack stands are on top.
Paul
Old 09-28-2020, 08:25 PM   #242
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Looks good! Glad to see you are making some progress on it.
LockDoc
Leon
Old 09-29-2020, 07:07 AM   #243
richard2717
Re: NJ Suburban
Looking good Paul. Lotta real estate to spray at one time
Members I have met.
Old 09-29-2020, 07:35 PM   #244
67swb72klb
67swb72klb's Avatar
Re: NJ Suburban
Nice work!!
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-30-2020, 08:54 AM   #245
HO455
HO455's Avatar
Re: NJ Suburban
Lots of great work there!
RIP Bob Parks.
Old 12-20-2020, 03:07 PM   #246
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Well this has been a long time coming.
Couple notes:
I used the Energy Suspension 3.4149G 1967-72 CHEV/GMC/.SUBURBAN polyurethane body bushing kit. It was missing several bushings but a call to Energy suspension got them shipped out really quick. Some of the bolts are the wrong style head and length. Research of the bolts shows that they are Grade 5 bolts. Two spots should have carriage bolts not hex head. Grade 5 carriage bolts are something I can get at my local hardware store.
The weirdest thing is that one of the body mount holes does not line up! I used a 68 2wd GMC body and put it on a 70 4wd Chevy frame. All the other body mounts line up. This makes me wonder if in fact the 2wd body is different from the 4wd body. I'll post pics of the difference later. Right now I'm so happy to have the body on the frame!
Paul
Old 12-20-2020, 03:11 PM   #247
richard2717
Re: NJ Suburban
Coming along pretty good. Looks nice.
Members I have met.
Old 12-20-2020, 03:13 PM   #248
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Thanks Richard!
Old 12-20-2020, 03:49 PM   #249
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
"The weirdest thing is that one of the body mount holes does not line up! I used a 68 2wd GMC body and put it on a 70 4wd Chevy frame. All the other body mounts line up. This makes me wonder if in fact the 2wd body is different from the 4wd body."
Nope! Figured it out. The bodies are the same.
Old 12-21-2020, 01:37 PM   #250
Burb
Coordinator of Synchronicity
Burb's Avatar
Re: NJ Suburban
Looks great
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
