Glue some cloth to door panels?
My current door panels are painted but I was thinking I could get another pair and try my hand at gluing some cloth on like the picture. Just wondering if anyone has done this? What kind of cloth to get? Would it have to be a little stretchy to get it to conform to the indents? I was thinking I could get a couple of helpers to hold it just above and start from the center out, rubbing it into the indents.
![]() Join Date: Apr 2010
Re: Glue some cloth to door panels?
Most any cloth will work, the material in your photo is a factory GM cloth. That stuff doesn’t have much stretch. I would avoid patterns or lines in the design, they will get distorted going over the shape of the panel.
I have used 3M super 77 when I don’t have access to commercial grade glue. It should work fine, but you should always test the glue on the material first. Glue can wick through some fabrics. Also, be sure to use washers on the screws just like the photo, to avoid cutting the cloth with the screws.
1951 Truck, LS1/4L60 1964 Suburban, current project |
Thanks for the tips jweb.
![]() Join Date: Jan 2011
The ones in my 66 are covered like the one in the pictures. The material matches my seat.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
